Ana içeriğe geç
Lenovo Yoga 710-15IKB Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-15IKB Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Battery Replacement: adım 2, 1 resimden 1.
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Battery Replacement: adım 3, 1 resimden 1.
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Battery Replacement: adım 4, 1 resimden 1.
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Battery Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Battery Replacement: adım 6, 1 resimden 1.
    • Gently lift and remove the battery.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Stephanie Alexander
745 İtibar
3 adet Kılavuz yazıldı
Ekip
2 Yorum
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
karenosickey - Yanıt
The battery cable requires a lot of force to disconnect; tweezers won't cut it. It's also difficult to reconnect the battery. I used two pairs of needle-nose pliers to squeeze the connector into the socket on both sides.
jkvmyxud - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 21
Son 30 gün: 99
Her zaman: 18,614
