Ana içeriğe geç
Lenovo Yoga 720-13IKB Fan Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 720-13IKB Fan Replacement, Bottom Cover: adım 1, 3 resimden 1. Lenovo Yoga 720-13IKB Fan Replacement, Bottom Cover: adım 1, 3 resimden 2. Lenovo Yoga 720-13IKB Fan Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720-13IKB Fan Replacement: adım 2, 3 resimden 1. Lenovo Yoga 720-13IKB Fan Replacement: adım 2, 3 resimden 2. Lenovo Yoga 720-13IKB Fan Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720-13IKB Fan Replacement: adım 3, 3 resimden 1. Lenovo Yoga 720-13IKB Fan Replacement: adım 3, 3 resimden 2. Lenovo Yoga 720-13IKB Fan Replacement: adım 3, 3 resimden 3.
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
  4. Lenovo Yoga 720-13IKB Fan Replacement, Fan: adım 4, 2 resimden 1. Lenovo Yoga 720-13IKB Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Use a JIS #000 screwdriver to unscrew and remove the seven 2.5mm screws that secure the fan to the motherboard.
    • Remove the fan from the laptop.
    • Follow the instructions found here to reapply new thermal paste. If your replacement heat sink and fan assembly has thermal paste pre-applied, you'll simply need to remove the old thermal paste from the laptop.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 60
Her zaman: 1,212
