Ana içeriğe geç
Levoit Core 300-RAC Power Board Replacement
Neye ihtiyacın var
    1. Levoit Core 300-RAC Power Board Replacement, Air Filter: adım 1, 2 resimden 1. Levoit Core 300-RAC Power Board Replacement, Air Filter: adım 1, 2 resimden 2.
      • Make sure your device is turned off and unplugged for safety.
      • Turn the Levoit Core 300-RAC over so the bottom is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Levoit Core 300-RAC Power Board Replacement: adım 2, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 2, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 2, 3 resimden 3.
      • Turn the bottom cover counterclockwise and lift it off to remove it.
      • The cover does not "snap" on or off when turned.
      FixBot'a Sor
      Yorum Ekle
    3. Levoit Core 300-RAC Power Board Replacement: adım 3, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 3, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 3, 3 resimden 3.
      • Lift the filter straight up and out of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Levoit Core 300-RAC Power Board Replacement, Power Board: adım 4, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement, Power Board: adım 4, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement, Power Board: adım 4, 3 resimden 3.
      • Use a Phillips #2 screwdriver to remove the four screws that secure the gray lid towards the base of the device.
      • Set the screws aside in a safe place.
      FixBot'a Sor
      Yorum Ekle
    2. Levoit Core 300-RAC Power Board Replacement: adım 5, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 5, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 5, 3 resimden 3.
      • Use a metal spudger or Jimmy to gently pry between the four white tabs and the white housing to release the outer housing.
      • Gently pulling up on the outer housing can prevent the clips from resetting.
      FixBot'a Sor
      Yorum Ekle
    3. Levoit Core 300-RAC Power Board Replacement: adım 6, 2 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 6, 2 resimden 2.
      • Remove the white outer housing and set it to the side.
      • The power cord is fed through a hole in the side of this housing, so it has to sit right next to the device.
      FixBot'a Sor
      Yorum Ekle
    4. Levoit Core 300-RAC Power Board Replacement: adım 7, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 7, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 7, 3 resimden 3.
      • Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
      FixBot'a Sor
      Yorum Ekle
    5. Levoit Core 300-RAC Power Board Replacement: adım 8, 2 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 8, 2 resimden 2.
      • Remove the four Phillips #2 screws securing the gray face plate.
      FixBot'a Sor
      Yorum Ekle
    6. Levoit Core 300-RAC Power Board Replacement: adım 9, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 9, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 9, 3 resimden 3.
      • Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
      • Lift it out.
      FixBot'a Sor
      Yorum Ekle
    7. Levoit Core 300-RAC Power Board Replacement: adım 10, 1 resimden 1.
      • Turn your device over so it is upright again.
      FixBot'a Sor
      Yorum Ekle
    8. Levoit Core 300-RAC Power Board Replacement: adım 11, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 11, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 11, 3 resimden 3.
      • Insert the Jimmy between the gray grille cover and the top of the device.
      • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
      • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
      • Remove the grille cover gently as it is connected by a ribbon cable.
      • Be careful not to put too much strain on the ribbon cable as it may break.
      FixBot'a Sor
      Yorum Ekle
    9. Levoit Core 300-RAC Power Board Replacement: adım 12, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 12, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 12, 3 resimden 3.
      • Squeeze the tab on the connector to release the bundled cable from the control board.
      • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
      FixBot'a Sor
      Yorum Ekle
    10. Levoit Core 300-RAC Power Board Replacement: adım 13, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 13, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 13, 3 resimden 3.
      • Insert a spudger or Jimmy into the four tabs to release them from holding the outer white housing to the inner black core.
      • Remove the white outer housing.
      FixBot'a Sor
      Yorum Ekle
    11. Levoit Core 300-RAC Power Board Replacement: adım 14, 2 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 14, 2 resimden 2.
      • Use a Phillips #2 screwdriver to remove the three screws holding the top of the black center section to the middle section.
      FixBot'a Sor
      Yorum Ekle
    12. Levoit Core 300-RAC Power Board Replacement: adım 15, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 15, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 15, 3 resimden 3.
      • Lift and remove the upper portion of the black core.
      FixBot'a Sor
      Yorum Ekle
    13. Levoit Core 300-RAC Power Board Replacement: adım 16, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 16, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 16, 3 resimden 3.
      • Insert a spudger into the slots around the seam to gently pry the upper part off of the assembly.
      FixBot'a Sor
      Yorum Ekle
    14. Levoit Core 300-RAC Power Board Replacement: adım 17, 2 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 17, 2 resimden 2.
      • Feed the ribbon connector through the space in the top part of the assembly before removing it.
      • Carefully pass the connector through the hole so you do not damage it.
      FixBot'a Sor
      Yorum Ekle
    15. Levoit Core 300-RAC Power Board Replacement: adım 18, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 18, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 18, 3 resimden 3.
      • Use your hands to pry apart the two tabs on opposite sides of the power board.
      • Use one hand to push on the tabs while gently lifting with your other hand to keep them from resetting.
      • There is a third tab that the board will slide out from under when the other two are released.
      • After releasing the two tabs shown, the power board will be free. Do not pull hard on the attached cables as that can damage them as well as other parts.
      FixBot'a Sor
      Yorum Ekle
    16. Levoit Core 300-RAC Power Board Replacement: adım 19, 3 resimden 1. Levoit Core 300-RAC Power Board Replacement: adım 19, 3 resimden 2. Levoit Core 300-RAC Power Board Replacement: adım 19, 3 resimden 3.
      • Squeeze down on the clips holding the connectors in place to release the cables.
      • The power board is now completely removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ryan Medeiros
353 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Petersen Fall 2023 UMass Dartmouth, Team 1-6, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G6
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 28
Son 30 gün: 108
Her zaman: 1,883
