Ana içeriğe geç
Levoit Core 300-RAC Power Cord Replacement
Neye ihtiyacın var
    1. Levoit Core 300-RAC Power Cord Replacement, Air Filter: adım 1, 2 resimden 1. Levoit Core 300-RAC Power Cord Replacement, Air Filter: adım 1, 2 resimden 2.
      • Make sure your device is turned off and unplugged for safety.
      • Turn the Levoit Core 300-RAC over so the bottom is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Levoit Core 300-RAC Power Cord Replacement: adım 2, 3 resimden 1. Levoit Core 300-RAC Power Cord Replacement: adım 2, 3 resimden 2. Levoit Core 300-RAC Power Cord Replacement: adım 2, 3 resimden 3.
      • Turn the bottom cover counterclockwise and lift it off to remove it.
      • The cover does not "snap" on or off when turned.
      FixBot'a Sor
      Yorum Ekle
    3. Levoit Core 300-RAC Power Cord Replacement: adım 3, 3 resimden 1. Levoit Core 300-RAC Power Cord Replacement: adım 3, 3 resimden 2. Levoit Core 300-RAC Power Cord Replacement: adım 3, 3 resimden 3.
      • Lift the filter straight up and out of the device.
      FixBot'a Sor
      Yorum Ekle
    1. Levoit Core 300-RAC Power Cord Replacement, Power Cord: adım 4, 3 resimden 1. Levoit Core 300-RAC Power Cord Replacement, Power Cord: adım 4, 3 resimden 2. Levoit Core 300-RAC Power Cord Replacement, Power Cord: adım 4, 3 resimden 3.
      • Use a Phillips #2 screwdriver to remove the four screws that go through the four white tabs inside the device
      • Set the screws aside in a safe place.
      FixBot'a Sor
      Yorum Ekle
    2. Levoit Core 300-RAC Power Cord Replacement: adım 5, 3 resimden 1. Levoit Core 300-RAC Power Cord Replacement: adım 5, 3 resimden 2. Levoit Core 300-RAC Power Cord Replacement: adım 5, 3 resimden 3.
      • Use a metal spudger to gently pry between the four white tabs and the white housing and release the outer housing.
      • Gently pull up on the outer housing to prevent the clips from resetting.
      FixBot'a Sor
      Yorum Ekle
    3. Levoit Core 300-RAC Power Cord Replacement: adım 6, 2 resimden 1. Levoit Core 300-RAC Power Cord Replacement: adım 6, 2 resimden 2.
      • Remove the white outer housing and set it to the side.
      • The power cord is fed through a hole in the side of this housing, so it will need to be right next to the rest of the device.
      FixBot'a Sor
      Yorum Ekle
    4. Levoit Core 300-RAC Power Cord Replacement: adım 7, 3 resimden 1. Levoit Core 300-RAC Power Cord Replacement: adım 7, 3 resimden 2. Levoit Core 300-RAC Power Cord Replacement: adım 7, 3 resimden 3.
      • Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
      FixBot'a Sor
      Yorum Ekle
    5. Levoit Core 300-RAC Power Cord Replacement: adım 8, 2 resimden 1. Levoit Core 300-RAC Power Cord Replacement: adım 8, 2 resimden 2.
      • Remove the four Phillips #2 screws securing the gray face plate.
      FixBot'a Sor
      Yorum Ekle
    6. Levoit Core 300-RAC Power Cord Replacement: adım 9, 3 resimden 1. Levoit Core 300-RAC Power Cord Replacement: adım 9, 3 resimden 2. Levoit Core 300-RAC Power Cord Replacement: adım 9, 3 resimden 3.
      • Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
      • Lift it out.
      FixBot'a Sor
      Yorum Ekle
    7. Levoit Core 300-RAC Power Cord Replacement: adım 10, 1 resimden 1.
      • Use wire cutters to carefully cut off the crimped power cord connections and remove the white power cord.
      • Cut as close to the connection as possible to leave as much of the internal wires as possible.
      • Cut your new power cable to length and replace the old one. You can splice the new cable on using a soldering iron, heat shrink tubing, and a heat gun. Alternatively, you can use twist-on wire nuts to make a secure connection. For more information on soldering, take a look at How to Solder and Desolder Connectors, and How to Use Heat Shrink Tubing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Kamp
589 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Petersen Fall 2023 UMass Dartmouth, Team 1-6, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G6
5 Üyeler
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
You're a lifesaver, thank you! My rabbit managed to reach the cable for mine and chewed it up, my allergies have been going crazy
Grace - Yanıt Paylaş
What type of cable did you use to replace the older one?
Mauricio Diaz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 29
Son 30 gün: 105
Her zaman: 3,293
