Giriş
Help fix the LCD and Digitizer to still promote ease of use. This will require multiple prying tools and a screwdriver.
Neye ihtiyacın var
First the case must be opened. Insert the blue plastic opening tool where the two casings meet. Pry up until you hear a clip pop and then carefully move around the device. Do this until the front and back casing are completely separate from one another.
You will see green grounding tape on the bottom left-hand corner of the LCD. Take a spudger and place it between the casing and the tape. Slowly pry up until you can peel the tape back.
3 farklı kişi bu kılavuzu tamamladı.
