Ana içeriğe geç
Lexibook Junior Tablet Battery Replacement
Neye ihtiyacın var
    1. Lexibook Junior Tablet Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Make sure your device is powered off before replacement to prevent electric shock.
      • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
      • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
      FixBot'a Sor
      Yorum Ekle
    2. Lexibook Junior Tablet Battery Replacement: adım 2, 1 resimden 1.
      • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
      • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
      • Use the plastic opening tool to gently pry open the back panel of the tablet.
      FixBot'a Sor
      Yorum Ekle
    3. Lexibook Junior Tablet Battery Replacement: adım 3, 1 resimden 1.
      • Use the nylon spudger to gently pry under the battery to remove it.
      • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
      FixBot'a Sor
      Yorum Ekle
    4. Lexibook Junior Tablet Battery Replacement: adım 4, 1 resimden 1.
      • Use a soldering iron to remove the battery from the motherboard safely.
      • For advice on how to solder, check out iFixit's Soldering Guide.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rachel Klesius
645 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-3, Blackwell Fall 2016 USF Tampa, Team 17-3, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G3
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Bonjour avez vous lien pour l'achat de la batterie en question. Merci
Akrame Chakir - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,653
