Ana içeriğe geç
Lexibook Junior Tablet Battery Replacement
Neye ihtiyacın var
  1. Lexibook Junior Tablet Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your device is powered off before replacement to prevent electric shock.
    • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
    • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
  2. Lexibook Junior Tablet Battery Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
    • Use the plastic opening tool to gently pry open the back panel of the tablet.
  3. Lexibook Junior Tablet Battery Replacement: adım 3, 1 resimden 1.
    • Use the nylon spudger to gently pry under the battery to remove it.
    • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
  4. Lexibook Junior Tablet Battery Replacement: adım 4, 1 resimden 1.
    • Use a soldering iron to remove the battery from the motherboard safely.
    • For advice on how to solder, check out iFixit's Soldering Guide.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rachel Klesius
645 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-3, Blackwell Fall 2016 USF Tampa, Team 17-3, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S17G3
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Bonjour avez vous lien pour l'achat de la batterie en question. Merci
Akrame Chakir - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,245
