Ana içeriğe geç
Lexmark Intuition S505 Scanner Unit Replacement
Neye ihtiyacın var
    1. Lexmark Intuition S505 Scanner Unit Replacement, Duplex Unit: adım 1, 1 resimden 1.
      • Hold the button down with the flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
      FixBot'a Sor
      Yorum Ekle
    2. Lexmark Intuition S505 Scanner Unit Replacement: adım 2, 2 resimden 1. Lexmark Intuition S505 Scanner Unit Replacement: adım 2, 2 resimden 2.
      • Remove the duplex unit from the back of the printer with the duplex unit facing up.
      FixBot'a Sor
      Yorum Ekle
    1. Lexmark Intuition S505 Scanner Unit Replacement, Scanner Unit: adım 3, 1 resimden 1.
      • Locate the two screw holes that connect the two cylindrical extensions from the top portion of the scanner unit to the printer.
      FixBot'a Sor
      Yorum Ekle
    2. Lexmark Intuition S505 Scanner Unit Replacement: adım 4, 1 resimden 1.
      • Unscrew the two size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
      FixBot'a Sor
      Yorum Ekle
    3. Lexmark Intuition S505 Scanner Unit Replacement: adım 5, 1 resimden 1.
      • Raise and close the scanner unit to observe that the hinges lock in place when lifted.
      FixBot'a Sor
      Yorum Ekle
    4. Lexmark Intuition S505 Scanner Unit Replacement: adım 6, 2 resimden 1. Lexmark Intuition S505 Scanner Unit Replacement: adım 6, 2 resimden 2.
      • Firmly press the hinges inward toward the middle of the printer on both sides at the same time. The hinges should be easily lifted up and removed.
      FixBot'a Sor
      Yorum Ekle
    5. Lexmark Intuition S505 Scanner Unit Replacement: adım 7, 1 resimden 1.
      • Locate the three screws connecting the plastic tray to the printer.
      FixBot'a Sor
      Yorum Ekle
    6. Lexmark Intuition S505 Scanner Unit Replacement: adım 8, 1 resimden 1.
      • Remove the three size#6 (5-mm head) Phillips 1-mm screws connecting the scanner unit to the printer.
      FixBot'a Sor
      Yorum Ekle
    7. Lexmark Intuition S505 Scanner Unit Replacement: adım 9, 1 resimden 1.
      • Remove the plastic cover by unlocking the plastic hinges at the inside edges of the printer. Use a plastic opening tool or a tweezer to slowly move in between the crease around the printer to unlock it.
      FixBot'a Sor
      Yorum Ekle
    8. Lexmark Intuition S505 Scanner Unit Replacement: adım 10, 2 resimden 1. Lexmark Intuition S505 Scanner Unit Replacement: adım 10, 2 resimden 2.
      • Slowly raise, but do not remove the plastic cover with the scanner unit so that it exposes the three cables connecting the scanner unit to the printer.
      FixBot'a Sor
      Yorum Ekle
    9. Lexmark Intuition S505 Scanner Unit Replacement: adım 11, 1 resimden 1.
      • Carefully unplug the pink cable.
      FixBot'a Sor
      Yorum Ekle
    10. Lexmark Intuition S505 Scanner Unit Replacement: adım 12, 1 resimden 1.
      • Carefully unplug the gray data cable.
      FixBot'a Sor
      Yorum Ekle
    11. Lexmark Intuition S505 Scanner Unit Replacement: adım 13, 1 resimden 1.
      • Carefully unplug the white ribbon data cable.
      FixBot'a Sor
      Yorum Ekle
    12. Lexmark Intuition S505 Scanner Unit Replacement: adım 14, 1 resimden 1.
      • Locate the three ports for the cables from the scanner unit and make sure they are unplugged.
      FixBot'a Sor
      Yorum Ekle
    13. Lexmark Intuition S505 Scanner Unit Replacement: adım 15, 1 resimden 1.
      • Remove the scanner unit with the plastic cover by lifting it up from the bottom portion of the printer.
      • Be careful with the paper tray and make sure it is evenly lifted through the rectangular hole in the plastic tray
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 farklı kişi bu kılavuzu tamamladı.
Raymond
48 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 üyesi
CPSU-REGAN-W13S18G38
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 1,744
