Ana içeriğe geç
Lighting: Replacing Light Emitting Diode
Neye ihtiyacın var
  1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: adım 1, 1 resimden 1.
    • Using a plastic opening tool, remove the base of the Light Angel.
    • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
    FixBot'a Sor
  2. Lighting: Replacing Light Emitting Diode: adım 2, 1 resimden 1.
    • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
    • To remove the screw, turn counterclockwise.
    • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
    FixBot'a Sor
  3. Lighting: Replacing Light Emitting Diode: adım 3, 1 resimden 1.
    • Remove and set aside the (4) AA batteries in the battery housing.
    FixBot'a Sor
  4. Lighting: Replacing Light Emitting Diode: adım 4, 1 resimden 1.
    • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
    • To remove the screws, turn counterclockwise.
    FixBot'a Sor
  5. Lighting: Replacing Light Emitting Diode: adım 5, 1 resimden 1.
    • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
    FixBot'a Sor
  6. Lighting: Replacing Light Emitting Diode: adım 6, 1 resimden 1.
    • Locate the faulty light emitting diode on the back of the circuit board.
    • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
    • Do not allow the soldering iron to come in contact with other components on the circuit board.
    • For detailed instructions on how to solder go to How To Solder and Desolder Connections
    FixBot'a Sor
  7. Lighting: Replacing Light Emitting Diode: adım 7, 1 resimden 1.
    • Insert the new light emitting diode through the two holes left from removing the old one.
    • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: How To Solder and Desolder Connections
    FixBot'a Sor
  8. Lighting: Replacing Light Emitting Diode: adım 8, 1 resimden 1.
    • Using solder and a soldering iron, solder the new LED to the circuit board.
    • Keep your solder joints separate to avoid short circuiting the circuit board.
    FixBot'a Sor
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 96
Her zaman: 6,570
