Ana içeriğe geç
Linksys EA9200 Antenna Port Replacement
Neye ihtiyacın var
  1. Linksys EA9200 Antenna Port  Replacement, Linksys EA9200 Disassembly: adım 1, 2 resimden 1. Linksys EA9200 Antenna Port  Replacement, Linksys EA9200 Disassembly: adım 1, 2 resimden 2.
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 Antenna Port  Replacement: adım 2, 2 resimden 1. Linksys EA9200 Antenna Port  Replacement: adım 2, 2 resimden 2.
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 Antenna Port  Replacement: adım 3, 3 resimden 1. Linksys EA9200 Antenna Port  Replacement: adım 3, 3 resimden 2. Linksys EA9200 Antenna Port  Replacement: adım 3, 3 resimden 3.
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 Antenna Port  Replacement: adım 4, 3 resimden 1. Linksys EA9200 Antenna Port  Replacement: adım 4, 3 resimden 2. Linksys EA9200 Antenna Port  Replacement: adım 4, 3 resimden 3.
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 Antenna Port  Replacement: adım 5, 3 resimden 1. Linksys EA9200 Antenna Port  Replacement: adım 5, 3 resimden 2. Linksys EA9200 Antenna Port  Replacement: adım 5, 3 resimden 3.
    • Lift the board and pull down, away from the antennas.
  6. Linksys EA9200 Antenna Port  Replacement, Antenna Port: adım 6, 2 resimden 1. Linksys EA9200 Antenna Port  Replacement, Antenna Port: adım 6, 2 resimden 2.
    • The antenna ports are connected to the board with a wire that has a "snap" connector.
  7. Linksys EA9200 Antenna Port  Replacement: adım 7, 2 resimden 1. Linksys EA9200 Antenna Port  Replacement: adım 7, 2 resimden 2.
    • Desolder the four pins of the antenna port.
    • Do not place the soldering iron on the wrong terminals as this can cause the device to no longer to function.
    • How To Solder and Desolder Connections is iFixit's official guide on how to use a soldering iron
    • You will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
    • Temperature of the component will be very hot when desoldered, take precaution when handling.
  8. Linksys EA9200 Antenna Port  Replacement: adım 8, 1 resimden 1.
    • Once the solder is melted, quickly pull broken antenna port.
Sonuç
Shane Davis
374 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Lacy Fall 2016 USF Tampa, Team 9-1, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 828
