Ana içeriğe geç
Linksys EA9200 USB Port Replacement
Neye ihtiyacın var
  1. Linksys EA9200 USB Port Replacement, Linksys EA9200 Disassembly: adım 1, 2 resimden 1. Linksys EA9200 USB Port Replacement, Linksys EA9200 Disassembly: adım 1, 2 resimden 2.
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 USB Port Replacement: adım 2, 2 resimden 1. Linksys EA9200 USB Port Replacement: adım 2, 2 resimden 2.
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 USB Port Replacement: adım 3, 3 resimden 1. Linksys EA9200 USB Port Replacement: adım 3, 3 resimden 2. Linksys EA9200 USB Port Replacement: adım 3, 3 resimden 3.
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 USB Port Replacement: adım 4, 3 resimden 1. Linksys EA9200 USB Port Replacement: adım 4, 3 resimden 2. Linksys EA9200 USB Port Replacement: adım 4, 3 resimden 3.
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 USB Port Replacement: adım 5, 3 resimden 1. Linksys EA9200 USB Port Replacement: adım 5, 3 resimden 2. Linksys EA9200 USB Port Replacement: adım 5, 3 resimden 3.
    • Lift the board and pull down, away from the antennas.
  6. Linksys EA9200 USB Port Replacement, USB Port: adım 6, 2 resimden 1. Linksys EA9200 USB Port Replacement, USB Port: adım 6, 2 resimden 2.
    • Desolder the 6 pin points fully.
    • How To Solder and Desolder Connections is iFixit's official guide on how to use a soldering iron.
    • You will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
    • Temperature of the component will be very hot when desoldered, take precaution when handling.
Sonuç
Shane Davis
374 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Lacy Fall 2016 USF Tampa, Team 9-1, Lacy Fall 2016 üyesi
USFT-LACY-F16S9G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 318
