Ana içeriğe geç
Linksys WAP54g LED Lights Replacement
Neye ihtiyacın var
  1. Linksys WAP54g LED Lights Replacement, Top Casing: adım 1, 1 resimden 1.
    • Power down and unplug the device.
    FixBot'a Sor
    Yorum Ekle
  2. Linksys WAP54g LED Lights Replacement: adım 2, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  3. Linksys WAP54g LED Lights Replacement: adım 3, 1 resimden 1.
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
    FixBot'a Sor
    Yorum Ekle
  4. Linksys WAP54g LED Lights Replacement: adım 4, 1 resimden 1.
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
    FixBot'a Sor
    Yorum Ekle
  5. Linksys WAP54g LED Lights Replacement: adım 5, 1 resimden 1.
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
    FixBot'a Sor
    Yorum Ekle
  6. Linksys WAP54g LED Lights Replacement: adım 6, 1 resimden 1.
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Linksys WAP54g LED Lights Replacement: adım 7, 2 resimden 1. Linksys WAP54g LED Lights Replacement: adım 7, 2 resimden 2.
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
    FixBot'a Sor
    Yorum Ekle
  8. Linksys WAP54g LED Lights Replacement: adım 8, 2 resimden 1. Linksys WAP54g LED Lights Replacement: adım 8, 2 resimden 2.
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
    FixBot'a Sor
    Yorum Ekle
  9. Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: adım 9, 2 resimden 1. Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: adım 9, 2 resimden 2.
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
    FixBot'a Sor
    Yorum Ekle
  10. Linksys WAP54g LED Lights Replacement, LED Lights: adım 10, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  11. Linksys WAP54g LED Lights Replacement: adım 11, 1 resimden 1.
    • Place new LED lights through holes created by desoldering and removing old lights.
    FixBot'a Sor
    Yorum Ekle
  12. Linksys WAP54g LED Lights Replacement: adım 12, 2 resimden 1. Linksys WAP54g LED Lights Replacement: adım 12, 2 resimden 2.
    • Solder the lights onto the bottom of the board to solidify the connection and make electrical contact.
    • Follow the Installing the Casing guide in reverse to re-assemble your device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Once the soldering is complete, the device should work and the LED lights should light up.
Bir başkası bu kılavuzu tamamladı.
Derek Myers
288 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-21, Maness Fall 2011 Cal Poly, Team 21-21, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G21
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 2,414
