Ana içeriğe geç
Linksys WRT54G Motherboard Component Replacement
Neye ihtiyacın var
    1. Linksys WRT54G Motherboard Component Replacement, Antennas: adım 1, 1 resimden 1.
      • Unfold the antennas straight away from the device.
      FixBot'a Sor
      Yorum Ekle
    2. Linksys WRT54G Motherboard Component Replacement: adım 2, 3 resimden 1. Linksys WRT54G Motherboard Component Replacement: adım 2, 3 resimden 2. Linksys WRT54G Motherboard Component Replacement: adım 2, 3 resimden 3.
      • Remove the black caps from the antennas by pulling them away from the device.
      FixBot'a Sor
      Yorum Ekle
    3. Linksys WRT54G Motherboard Component Replacement: adım 3, 3 resimden 1. Linksys WRT54G Motherboard Component Replacement: adım 3, 3 resimden 2. Linksys WRT54G Motherboard Component Replacement: adım 3, 3 resimden 3.
      • Unscrew each of the antennas from the wireless device.
      FixBot'a Sor
      Yorum Ekle
    1. Linksys WRT54G Motherboard Component Replacement, Casing: adım 4, 2 resimden 1. Linksys WRT54G Motherboard Component Replacement, Casing: adım 4, 2 resimden 2.
      • Using a bit of force, remove the blue plastic case.
      FixBot'a Sor
      Yorum Ekle
    1. Linksys WRT54G Motherboard Component Replacement, Motherboard: adım 5, 2 resimden 1. Linksys WRT54G Motherboard Component Replacement, Motherboard: adım 5, 2 resimden 2.
      • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
      • Pull the top piece upwards and away from the bottom to remove.
      FixBot'a Sor
      Yorum Ekle
    2. Linksys WRT54G Motherboard Component Replacement: adım 6, 2 resimden 1. Linksys WRT54G Motherboard Component Replacement: adım 6, 2 resimden 2.
      • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
      • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Linksys WRT54G Motherboard Component Replacement: adım 7, 1 resimden 1.
      • Once screws have been removed, slide the motherboard in the direction of its LED lights.
      • Lift motherboard up and away from the black lower casing.
      FixBot'a Sor
      Yorum Ekle
    1. Linksys WRT54G Motherboard Component Replacement, Motherboard Component: adım 8, 1 resimden 1.
      • Obtain a desoldering wick (Desoldering Braid). Plug in soldering iron and allow to heat. For soldering information, refer to the iFixit soldering guide (Lehimleme ve Lehim Sökme Bağlantıları Nasıl Yapılır).
      • Make sure that the soldering iron is not resting on top of anything that would be damaged by the heat.
      FixBot'a Sor
      Yorum Ekle
    2. Linksys WRT54G Motherboard Component Replacement: adım 9, 2 resimden 1. Linksys WRT54G Motherboard Component Replacement: adım 9, 2 resimden 2.
      • Identify the functional component which will be removed.
      • Turn the board over so that the pins holding the component in are exposed.
      FixBot'a Sor
      Yorum Ekle
    3. Linksys WRT54G Motherboard Component Replacement: adım 10, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicole C
114 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-7, Regan Fall 2011 Cal Poly, Team 17-7, Regan Fall 2011 üyesi
CPSU-REGAN-F11S17G7
4 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
Se puede sustituir el puerto de entrada de Internet que es de red, por uno de telefono DSL?
Vladimir Velázquez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 4,297
