Ana içeriğe geç
Linksys WRT54GS v2 Power Connector Replacement
Neye ihtiyacın var
  1. Linksys WRT54GS v2 Power Connector Replacement, Front Case: adım 1, 1 resimden 1.
    • Turn the router over so that all four of its feet are facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. Linksys WRT54GS v2 Power Connector Replacement: adım 2, 1 resimden 1.
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
    FixBot'a Sor
    Yorum Ekle
  3. Linksys WRT54GS v2 Power Connector Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Linksys WRT54GS v2 Power Connector Replacement: adım 4, 1 resimden 1.
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
    FixBot'a Sor
    Yorum Ekle
  5. Linksys WRT54GS v2 Power Connector Replacement, Motherboard: adım 5, 1 resimden 1.
    • Slide the board unit out and up.
    FixBot'a Sor
    Yorum Ekle
  6. Linksys WRT54GS v2 Power Connector Replacement: adım 6, 1 resimden 1.
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  7. Linksys WRT54GS v2 Power Connector Replacement, Power Connector: adım 7, 1 resimden 1.
    • Turn the circuit board over.
    • Identify the solder connections on the board, marked in red.
    FixBot'a Sor
    Yorum Ekle
  8. Linksys WRT54GS v2 Power Connector Replacement: adım 8, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Alex Do
51 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 3-4, Regan Fall 2011 Cal Poly, Team 3-4, Regan Fall 2011 üyesi
CPSU-REGAN-F11S3G4
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 2,218
