Ana içeriğe geç
Lite-On iHAS324 Eject Button and Power LED Light Replacement
Neye ihtiyacın var
    1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: adım 1, 2 resimden 1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Chassis: adım 1, 2 resimden 2.
      • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
      • There may be resistance, do not be afraid to use force.
      • The tray should then pop open.
      • Pull out the tray so that it is fully extended.
      FixBot'a Sor
      Yorum Ekle
    2. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 2, 3 resimden 1. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 2, 3 resimden 2. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 2, 3 resimden 3.
      • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
      FixBot'a Sor
      Yorum Ekle
    3. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 3, 1 resimden 1.
      • Pull the faceplate off the chassis.
      • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
      FixBot'a Sor
      Yorum Ekle
    4. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 4, 1 resimden 1.
      • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
      FixBot'a Sor
      Yorum Ekle
    5. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 5, 1 resimden 1.
      • Remove the bottom plate by lifting it off the device.
      FixBot'a Sor
      Yorum Ekle
    6. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 6, 1 resimden 1.
      • Turn the device over.
      • Remove the top plate by pulling the sides and lifting the plate off.
      FixBot'a Sor
      Yorum Ekle
    1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: adım 7, 2 resimden 1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray: adım 7, 2 resimden 2.
      • Push the left tab in and slide the tray out on the left side.
      • Pull the gray plastic casing on the right side away from the tray.
      • Slide the right side of the tray out.
      FixBot'a Sor
      Yorum Ekle
    1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Disc Tray Belt: adım 8, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Take tweezers and remove the black tray belt from the gears carefully.
      FixBot'a Sor
      Yorum Ekle
    1. Lite-On iHAS324 Eject Button and Power LED Light Replacement, Eject Button and Power LED Light: adım 9, 1 resimden 1.
      • Flip the device over.
      FixBot'a Sor
      Yorum Ekle
    2. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 10, 1 resimden 1.
      • Use a plastic opening tool to pull all three tabs, lifting up the circuit board as you go.
      FixBot'a Sor
      Yorum Ekle
    3. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 11, 1 resimden 1.
      • Carefully lift the circuit board out of the plastic casing.
      FixBot'a Sor
      Yorum Ekle
    4. Lite-On iHAS324 Eject Button and Power LED Light Replacement: adım 12, 1 resimden 1.
      • Using a solder wick, unsolder either the eject button or Power LED Light. Soldering Guide
      • Then, using a solder iron, replace them.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kayla Culpepper
726 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-9, Williams Spring 2015 Baylor, Team 5-9, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G9
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 44
Her zaman: 1,325
