Ana içeriğe geç
Logitech G Cloud Right Joystick Replacement
Neye ihtiyacın var
  1. Logitech G Cloud Right Joystick Replacement, Case: adım 1, 2 resimden 1. Logitech G Cloud Right Joystick Replacement, Case: adım 1, 2 resimden 2.
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech G Cloud Right Joystick Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech G Cloud Right Joystick Replacement: adım 3, 2 resimden 1. Logitech G Cloud Right Joystick Replacement: adım 3, 2 resimden 2.
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech G Cloud Right Joystick Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech G Cloud Right Joystick Replacement: adım 5, 2 resimden 1. Logitech G Cloud Right Joystick Replacement: adım 5, 2 resimden 2.
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech G Cloud Right Joystick Replacement, Right Joystick: adım 6, 3 resimden 1. Logitech G Cloud Right Joystick Replacement, Right Joystick: adım 6, 3 resimden 2. Logitech G Cloud Right Joystick Replacement, Right Joystick: adım 6, 3 resimden 3.
    • Use a spudger to lift upwards and disconnect the metallic sticker from the console.
    • The sticker should stay attached to the joystick plate.
    • Insert the flat end of a spudger under the joystick press connector and lift upwards to disconnect it.
    • Use a spudger to remove the R2 trigger sensor from the joystick plate; it should stay attached to the console.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech G Cloud Right Joystick Replacement: adım 7, 2 resimden 1. Logitech G Cloud Right Joystick Replacement: adım 7, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove all three 10 mm screws that secure the joystick assembly.
    • Pop the joystick out with your fingers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 62
Her zaman: 591
