Ana içeriğe geç
Logitech G PRO Wireless Feet Replacement
Neye ihtiyacın var
    1. Logitech G PRO Wireless Feet Replacement, Turn off the PRO Wireless: adım 1, 3 resimden 1. Logitech G PRO Wireless Feet Replacement, Turn off the PRO Wireless: adım 1, 3 resimden 2. Logitech G PRO Wireless Feet Replacement, Turn off the PRO Wireless: adım 1, 3 resimden 3.
      • Shift the power switch down to turn off your mouse (when the PRO Wireless label is oriented right-side up).
      • The color behind the switch should be red when the mouse is switched off.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech G PRO Wireless Feet Replacement, Apply heat to the upper mouse foot: adım 2, 1 resimden 1.
      • If you plan to reuse the mouse feet, you'll need to apply heat to loosen the adhesive and remove the feet with minimal bending.
      • Heat an iOpener and apply it to the upper mouse foot for one minute.
      • A hair dryer or heat gun may also be used, but be careful not to overheat the mouse—the internal battery is susceptible to heat damage. If you use a hair dryer or heat gun, set it to the lowest temperature setting and apply heat for 10 seconds.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech G PRO Wireless Feet Replacement, Insert the spudger under the upper mouse foot: adım 3, 2 resimden 1. Logitech G PRO Wireless Feet Replacement, Insert the spudger under the upper mouse foot: adım 3, 2 resimden 2.
      • Insert the flat end of a spudger under the upper mouse foot.
      • Each mouse foot has a gap in its recess that you can use to insert the spudger.
      • The mouse feet are made of two layers. Make sure you insert the spudger under the bottom layer to completely remove the foot.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech G PRO Wireless Feet Replacement, Remove the upper mouse foot: adım 4, 3 resimden 1. Logitech G PRO Wireless Feet Replacement, Remove the upper mouse foot: adım 4, 3 resimden 2. Logitech G PRO Wireless Feet Replacement, Remove the upper mouse foot: adım 4, 3 resimden 3.
      • Slide the spudger under the length of the upper mouse foot to cut through the adhesive and detach it from the mouse.
      • Work slowly to avoid bending the mouse foot. If the adhesive becomes difficult to cut through, remove the spudger and apply more heat.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech G PRO Wireless Feet Replacement, Apply heat to the lower mouse feet: adım 5, 1 resimden 1.
      • Apply the iOpener to the lower mouse feet for one minute.
      • Alternatively, use a hair dryer or heat gun to apply heat for ten seconds.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech G PRO Wireless Feet Replacement, Remove the lower mouse feet: adım 6, 2 resimden 1. Logitech G PRO Wireless Feet Replacement, Remove the lower mouse feet: adım 6, 2 resimden 2.
      • Insert the flat end of a spudger under the left lower mouse foot.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech G PRO Wireless Feet Replacement: adım 7, 3 resimden 1. Logitech G PRO Wireless Feet Replacement: adım 7, 3 resimden 2. Logitech G PRO Wireless Feet Replacement: adım 7, 3 resimden 3.
      • Slide the spudger under the length of the left lower mouse foot to cut through the adhesive and detach it from the mouse.
      FixBot'a Sor
      Yorum Ekle
    8. Logitech G PRO Wireless Feet Replacement: adım 8, 2 resimden 1. Logitech G PRO Wireless Feet Replacement: adım 8, 2 resimden 2.
      • Repeat the procedure to remove the two remaining lower mouse feet.
      FixBot'a Sor
      Yorum Ekle
    9. Logitech G PRO Wireless Feet Replacement, Adhesive information: adım 9, 1 resimden 1.
      • If you're going to install replacement mouse feet or apply new adhesive, use the flat edge of a spudger to remove the remaining adhesive in the mouse foot recesses.
      • If there's any adhesive residue left, use isopropyl alcohol and a microfiber cloth to remove it. Allow the surface to completely dry.
      • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the mouse feet.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kyle Smith
52.763 İtibar
124 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 57
Son 30 gün: 229
Her zaman: 15,693
