Ana içeriğe geç
Logitech G27 Shifter Potentiometer Replacement
Neye ihtiyacın var
  1. Logitech G27 Shifter Potentiometer Replacement, Shifter Potentiometer: adım 1, 1 resimden 1.
    • Remove the six 9.0mm allen screws with a 2.5mm hex key.
  2. Logitech G27 Shifter Potentiometer Replacement: adım 2, 1 resimden 1.
    • Either use the plastic opening tools or a flat screwdriver to pry and pop off the cap on the shifter.
  3. Logitech G27 Shifter Potentiometer Replacement: adım 3, 2 resimden 1. Logitech G27 Shifter Potentiometer Replacement: adım 3, 2 resimden 2.
    • Remove the black 12.3mm screw inside the shifter with a Phillips #1 screwdriver.
    • After, remove the shifter top and shifter boot cover by pulling straight up.
    • Remove the three 15.6mm screws with a Phillips #1 screwdriver.
  4. Logitech G27 Shifter Potentiometer Replacement: adım 4, 1 resimden 1.
    • Flip the device over and four 15.6mm screws with a Phillips #1 screwdriver.
    • Pull the lower clamp up and out of the shifter assembly.
  5. Logitech G27 Shifter Potentiometer Replacement: adım 5, 3 resimden 1. Logitech G27 Shifter Potentiometer Replacement: adım 5, 3 resimden 2. Logitech G27 Shifter Potentiometer Replacement: adım 5, 3 resimden 3.
    • Remove the two 10mmm hex nuts with a 10mm socket and a ratchet.
    • Next, unscrew the clamps by holding the lower portion of the shifter and unscrewing the top part.
    • Also remove the nut on the screw if it wasn't removed with the lower clamp.
  6. Logitech G27 Shifter Potentiometer Replacement: adım 6, 1 resimden 1.
    • Remove the eight black 11.9mm screws from the bottom housing with a Phillips #1 screwdriver.
  7. Logitech G27 Shifter Potentiometer Replacement: adım 7, 2 resimden 1. Logitech G27 Shifter Potentiometer Replacement: adım 7, 2 resimden 2.
    • Carefully lift the top half of the housing from the bottom.
    • Watch out, there are 2 wires attached to the PCB board. Be careful not to damage these in any way.
  8. Logitech G27 Shifter Potentiometer Replacement: adım 8, 1 resimden 1.
    • Carefully remove the two plastic connectors with a plastic opening tool or your hands.
  9. Logitech G27 Shifter Potentiometer Replacement: adım 9, 1 resimden 1.
    • Go to the lower portion of the shifter; remove two black screws and four silver 15.9mm screws with a Phillips #1 screwdriver.
  10. Logitech G27 Shifter Potentiometer Replacement: adım 10, 2 resimden 1. Logitech G27 Shifter Potentiometer Replacement: adım 10, 2 resimden 2.
    • There is grease covering the whole shifting assembly so it will get messy when removing.
    • Squeeze the two metal plates together and slowly pull up. The assembly is spring loaded and will fall apart if it is not squeezed.
  11. Logitech G27 Shifter Potentiometer Replacement: adım 11, 2 resimden 1. Logitech G27 Shifter Potentiometer Replacement: adım 11, 2 resimden 2.
    • Remove the shifter assembly and place it on a flat surface. Then remove the metal plate with the spring and ball bearing attached.
    • This is the hardest part of reassembling. Make sure to properly place the spring inside of the inner housing and the ball bearing on top. Place the other metal piece on top of it.
  12. Logitech G27 Shifter Potentiometer Replacement: adım 12, 3 resimden 1. Logitech G27 Shifter Potentiometer Replacement: adım 12, 3 resimden 2. Logitech G27 Shifter Potentiometer Replacement: adım 12, 3 resimden 3.
    • You will now have access to the two potentiometers on the sides of the assembly. Make sure they are properly connected and if need be, replace them by removing.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Nicholas Gholdoian
1.239 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-4, Amido Spring 2015 Cal Poly, Team 15-4, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S15G4
4 Üyeler
25 adet Kılavuz yazıldı
16Kılavuz Yorumları
Where can I buy replacement pots?
Riccardo Flask - Yanıt
Great guide, thanks a lot for the effort. It turned out that one of the cables connecting the pot to the pcb had snapped. Just going to test now.....fingers crossed. :-)
Cheers. Andy M.
Andy Mitchell - Yanıt
Hey did It work?
Levente Gergely -
I didn't even have to replace them. Only cleaning with electronic cleaning spray and move the pots fully was enough to fix it. However, and I think that was the real problem, one of the pots was damaged because the plastic pointer it has to be inplace in the assembly was broken. Only one half was in place. I used something here we call "type cleaner clay", some sort of clay not use to play but to fix things to the wall or clenaning old typewriters. Comonly blue. Other forums says damaged pots are not common, only dirty or may be, as mine broken. Easy to fix
Ricker Silva - Yanıt
Has anybody found a source for these pots? I'm guessing they're proprietary? Possibly some version of CTS 252 series? Anything they can be replaced with? I've worked on a couple of these where people opened up the shifter pots trying to clean them and damaged them, and I cannot for the life of me find any replacements and I've searched high and low through every joystick potentiometer source I could find.
David Riley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 163
Son 30 gün: 557
Her zaman: 65,732
