Ana içeriğe geç
Logitech G432 Audio Cable Replacement
Neye ihtiyacın var
  1. Logitech G432 Audio Cable Replacement, Earpad Cushions: adım 1, 2 resimden 1. Logitech G432 Audio Cable Replacement, Earpad Cushions: adım 1, 2 resimden 2.
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Audio Cable Replacement, Audio Cable: adım 2, 3 resimden 1. Logitech G432 Audio Cable Replacement, Audio Cable: adım 2, 3 resimden 2. Logitech G432 Audio Cable Replacement, Audio Cable: adım 2, 3 resimden 3.
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Audio Cable Replacement: adım 3, 1 resimden 1.
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
  4. Logitech G432 Audio Cable Replacement: adım 4, 1 resimden 1.
    • Raise the small component fastened to the wiring at the bottom of the earpiece to reveal each wire.
  5. Logitech G432 Audio Cable Replacement: adım 5, 1 resimden 1.
    • Extend the wiring to expose the tiny knots located along the audio cable.
    • Unravel the knots to disconnect the wires using a soldering iron, making it possible to connect the new audio cable.
Sonuç
Lara Vasquez
412 İtibar
4 adet Kılavuz yazıldı
Ekip
Marist, Team 1-2, Chaterdon Spring 2023 Marist, Team 1-2, Chaterdon Spring 2023 üyesi
MARS-CHATERDON-S23S1G2
3 Üyeler
9 adet Kılavuz yazıldı
2Kılavuz Yorumları
Vous pourriez mettre la référence du câble ?
Jean Morlet - Yanıt
pour le moins tuto incomplet , on aimerai voir effectivement le replacement du cable, en effet, le cable d'origine comporte 6 conducteurs alors que les cables de remplacement n'en comportent que 4. La réparation ne s'arrete donc pas à remplacer les fils un par un (en plus la couleur des fils n'est pas la meme qu'à l'origine) il faut modifier le cablage d'origine : déplacer une tresse de masse et souder 2 straps......
marc miettaux - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 117
Her zaman: 4,190
