Giriş
If the audio in your Logitech G432 stops working or is inconsistent, or the physical cable appears to be broken, you most likely have a faulty audio cable that requires replacement.
A functional audio cable transfers sound from your PC to the speakers in your headset. If this audio cable is damaged in some way by outside factors or is simply overused for a long period of time, the sound will start to go in and out. Before deciding a replacement is necessary, you must make sure the issue is with the audio cable and not the speaker. One way to test this is by listening to each speaker one at a time. If both speakers sound faulty, the issue is likely with the audio cable. Another way to tell is if the cable is visibly broken.
Make sure to power down your device and disconnect it from your PC before beginning the replacement process.
Neye ihtiyacın var
Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
Extend the wiring to expose the tiny knots located along the audio cable.
Unravel the knots to disconnect the wires using a soldering iron, making it possible to connect the new audio cable.
2Kılavuz Yorumları
Vous pourriez mettre la référence du câble ?
pour le moins tuto incomplet , on aimerai voir effectivement le replacement du cable, en effet, le cable d'origine comporte 6 conducteurs alors que les cables de remplacement n'en comportent que 4. La réparation ne s'arrete donc pas à remplacer les fils un par un (en plus la couleur des fils n'est pas la meme qu'à l'origine) il faut modifier le cablage d'origine : déplacer une tresse de masse et souder 2 straps......
