Ana içeriğe geç
Logitech G920 Driving Force Steering Wheel Motherboard Replacement
Neye ihtiyacın var
  1. Logitech G920 Driving Force Steering Wheel Motherboard Replacement, Steering Wheel Motherboard: adım 1, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: adım 3, 2 resimden 1. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: adım 3, 2 resimden 2.
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: adım 4, 2 resimden 1. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: adım 5, 2 resimden 1. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the eight 7.5 mm screws holding the steering wheel motherboard in place using a Phillips #0 screwdriver.
    • Remove the steering wheel motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tristyn Dolan
309 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
what is on the wire that connect to the motherborade
saleh - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 36
Son 30 gün: 125
Her zaman: 2,805
