Ana içeriğe geç
Logitech Harmony 650 Screen Replacement
Neye ihtiyacın var
  1. Logitech Harmony 650 Screen Replacement, Case: adım 1, 2 resimden 1. Logitech Harmony 650 Screen Replacement, Case: adım 1, 2 resimden 2.
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Harmony 650 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the batteries using the silver pull tab.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Harmony 650 Screen Replacement: adım 3, 1 resimden 1.
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech Harmony 650 Screen Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech Harmony 650 Screen Replacement: adım 5, 1 resimden 1.
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech Harmony 650 Screen Replacement: adım 6, 2 resimden 1. Logitech Harmony 650 Screen Replacement: adım 6, 2 resimden 2.
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech Harmony 650 Screen Replacement: adım 7, 1 resimden 1.
    • Remove the rear cover.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech Harmony 650 Screen Replacement, Motherboard: adım 8, 2 resimden 1. Logitech Harmony 650 Screen Replacement, Motherboard: adım 8, 2 resimden 2.
    • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
    FixBot'a Sor
    Yorum Ekle
  9. Logitech Harmony 650 Screen Replacement: adım 9, 1 resimden 1.
    • Remove the motherboard by gently pulling it away from the case.
    FixBot'a Sor
    Yorum Ekle
  10. Logitech Harmony 650 Screen Replacement, Screen: adım 10, 2 resimden 1. Logitech Harmony 650 Screen Replacement, Screen: adım 10, 2 resimden 2.
    • Remove the black rubber gasket that surrounds the screen from the top face of the motherboard.
    • The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
    FixBot'a Sor
    Yorum Ekle
  11. Logitech Harmony 650 Screen Replacement: adım 11, 1 resimden 1.
    • Use a soldering iron to loosen the solder that connects the screen strip to the back of the motherboard. If it does not loosen easily then try using a soldering remover wick.
    • The soldering iron gets extremely hot use caution when using it around components.
    FixBot'a Sor
    Yorum Ekle
  12. Logitech Harmony 650 Screen Replacement: adım 12, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  13. Logitech Harmony 650 Screen Replacement: adım 13, 1 resimden 1.
    • Use a spudger or your hand to remove the screen from the motherboard. It is glued down.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hey will beat buy honor a warrenty
antonioofficial - Yanıt Paylaş
so where can i buy the screen!!!!
shortemperd Gotico - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 42
Her zaman: 3,250
