Ana içeriğe geç
Logitech Harmony Smart Control Battery Contact Replacement
Neye ihtiyacın var
  1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: adım 1, 2 resimden 1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: adım 1, 2 resimden 2.
    • Use both thumbs to slide the grooved cover off of the remote
    • Once the cover is off, remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Harmony Smart Control Battery Contact  Replacement: adım 2, 2 resimden 1. Logitech Harmony Smart Control Battery Contact  Replacement: adım 2, 2 resimden 2.
    • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Harmony Smart Control Battery Contact  Replacement: adım 3, 3 resimden 1. Logitech Harmony Smart Control Battery Contact  Replacement: adım 3, 3 resimden 2. Logitech Harmony Smart Control Battery Contact  Replacement: adım 3, 3 resimden 3.
    • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech Harmony Smart Control Battery Contact  Replacement: adım 4, 2 resimden 1. Logitech Harmony Smart Control Battery Contact  Replacement: adım 4, 2 resimden 2.
    • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
    • Slide the circuit board out from the housing .
    FixBot'a Sor
    Yorum Ekle
  5. Logitech Harmony Smart Control Battery Contact  Replacement: adım 5, 1 resimden 1.
    • Locate the battery contacts on the circuit board.
    • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Josh Hendricks
464 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G2
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 5,329
