Ana içeriğe geç
Logitech Harmony Smart Control Charging Port Replacement
Neye ihtiyacın var
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: adım 1, 2 resimden 1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: adım 1, 2 resimden 2.
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: adım 2, 2 resimden 1. Logitech Harmony Smart Control Charging Port Replacement: adım 2, 2 resimden 2.
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: adım 3, 2 resimden 1. Logitech Harmony Smart Control Charging Port Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: adım 4, 2 resimden 1. Logitech Harmony Smart Control Charging Port Replacement: adım 4, 2 resimden 2.
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: adım 5, 3 resimden 1. Logitech Harmony Smart Control Charging Port Replacement: adım 5, 3 resimden 2. Logitech Harmony Smart Control Charging Port Replacement: adım 5, 3 resimden 3.
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: adım 6, 3 resimden 1. Logitech Harmony Smart Control Charging Port Replacement: adım 6, 3 resimden 2. Logitech Harmony Smart Control Charging Port Replacement: adım 6, 3 resimden 3.
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josh Hendricks
464 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 862
