Ana içeriğe geç
Logitech Harmony Smart Control Hub Light Bulb Replacement
Neye ihtiyacın var
  1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: adım 1, 2 resimden 1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: adım 1, 2 resimden 2.
    • Use a spudger to lift up one of the rubber pads on the bottom of the hub.
    • Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
    • Repeat for the second rubber pad.
  2. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 2, 2 resimden 1. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 2, 2 resimden 2.
    • Use a PH00 screwdriver bit to remove the four 6mm Phillips screws on the bottom of the device.
  3. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 3, 2 resimden 1. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 3, 2 resimden 2.
    • Use a spudger to separate the top and bottom pieces of the device.
  4. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 4, 2 resimden 1. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 4, 2 resimden 2.
    • Use the PH00 screwdriver bit to unscrew the three 4mm Phillips screws on the control board.
  5. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 5, 2 resimden 1. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 5, 2 resimden 2.
    • Place the end of the opening tool under the yellow corner of the circuit board as shown.
    • Gently push upward to pry the board from its housing.
  6. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 6, 3 resimden 1. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 6, 3 resimden 2. Logitech Harmony Smart Control Hub Light Bulb Replacement: adım 6, 3 resimden 3.
    • Determine which of the five bulbs are defective.
    • Turn the board over to expose the bulb solder.
    • Using a soldering iron, remove the solder and bulb. Replace with a new bulb and re-solder.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Josh Hendricks
464 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 567
