Ana içeriğe geç
Logitech Harmony Smart Control Reset Button Replacement
Neye ihtiyacın var
  1. Logitech Harmony Smart Control Reset Button Replacement, Reset Button: adım 1, 2 resimden 1. Logitech Harmony Smart Control Reset Button Replacement, Reset Button: adım 1, 2 resimden 2.
    • Using a plastic opening tool, lift up the rubber pad.
    • From the bottom of the device, with your fingers, pull back the rubber pad. This will expose the screw holes.
    • On the bottom of the hub, repeat the step above for the second rubber pad.
  2. Logitech Harmony Smart Control Reset Button Replacement: adım 2, 2 resimden 1. Logitech Harmony Smart Control Reset Button Replacement: adım 2, 2 resimden 2.
    • With the PH00 bit, remove the four 6mm Phillips screws.
  3. Logitech Harmony Smart Control Reset Button Replacement: adım 3, 2 resimden 1. Logitech Harmony Smart Control Reset Button Replacement: adım 3, 2 resimden 2.
    • With the plastic opening tool, separate the pieces of plastic from each other
  4. Logitech Harmony Smart Control Reset Button Replacement: adım 4, 2 resimden 1. Logitech Harmony Smart Control Reset Button Replacement: adım 4, 2 resimden 2.
    • With the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Reset Button Replacement: adım 5, 3 resimden 1. Logitech Harmony Smart Control Reset Button Replacement: adım 5, 3 resimden 2. Logitech Harmony Smart Control Reset Button Replacement: adım 5, 3 resimden 3.
    • From the yellow corner, pry the circuit board from the housing..
  6. Logitech Harmony Smart Control Reset Button Replacement: adım 6, 3 resimden 1. Logitech Harmony Smart Control Reset Button Replacement: adım 6, 3 resimden 2. Logitech Harmony Smart Control Reset Button Replacement: adım 6, 3 resimden 3.
    • Locate the defective reset button.
    • Turn the board around to expose the reset solder.
    • Using soldering iron, remove solder and reset button. Replace reset button and solder.
Sonuç
Zachary Robinson
126 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Fall 2015 IUPUI, Team 3-2, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S3G2
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,055
