Giriş
This guide requires soldering, for soldering guide click below.
Neye ihtiyacın var
Using a plastic opening tool, lift up the rubber pad.
From the bottom of the device, with your fingers, pull back the rubber pad. This will expose the screw holes.
On the bottom of the hub, repeat the step above for the second rubber pad.
