Ana içeriğe geç
Logitech M310 Mouse Wheel Spring Repair
Neye ihtiyacın var
  1. Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: adım 1, 2 resimden 1. Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: adım 1, 2 resimden 2.
    • Check if the scroll wheel is spinning freely without resistance.
    • A correctly aligned spring will cause the wheel to ratchet in small increments
  2. Logitech M310 Mouse Wheel Spring Repair: adım 2, 3 resimden 1. Logitech M310 Mouse Wheel Spring Repair: adım 2, 3 resimden 2. Logitech M310 Mouse Wheel Spring Repair: adım 2, 3 resimden 3.
    • Use your thumb to press the indentation on the bottom battery cover.
    • Slide down the battery cover and fully remove the battery cover.
    • Remove the battery.
  3. Logitech M310 Mouse Wheel Spring Repair: adım 3, 3 resimden 1. Logitech M310 Mouse Wheel Spring Repair: adım 3, 3 resimden 2. Logitech M310 Mouse Wheel Spring Repair: adım 3, 3 resimden 3.
    • Remove two Phillips #1 screws.
  4. Logitech M310 Mouse Wheel Spring Repair: adım 4, 3 resimden 1. Logitech M310 Mouse Wheel Spring Repair: adım 4, 3 resimden 2. Logitech M310 Mouse Wheel Spring Repair: adım 4, 3 resimden 3.
    • Remove the bottom board plate from the mouse body by pulling it down and away.
    • Ensure not to apply the force perpendicular to the mouse body. The board will only remove in a downward direction.
  5. Logitech M310 Mouse Wheel Spring Repair: adım 5, 3 resimden 1. Logitech M310 Mouse Wheel Spring Repair: adım 5, 3 resimden 2. Logitech M310 Mouse Wheel Spring Repair: adım 5, 3 resimden 3.
    • Use the 2mm flat head to lift up the spring leg.
    • Use the screwdriver as a lever to pry the spring leg back into the scroll wheel
    • You may need to use your thumb to pull the scroll wheel to the left a few millimeters, creating enough of a gap on the right side for the spring leg to fit into the mouse wheel cavity.
    • The spring leg should no longer be visible once aligned inside the mouse wheel cavity.
  6. Logitech M310 Mouse Wheel Spring Repair: adım 6, 3 resimden 1. Logitech M310 Mouse Wheel Spring Repair: adım 6, 3 resimden 2. Logitech M310 Mouse Wheel Spring Repair: adım 6, 3 resimden 3.
    • Before reassembling the mouse, confirm if the scroll wheel is fixed appropriately.
    • Gently place the mouse down on the table and scroll the wheel. There should now be a noticeable difference in resistance, and it should no longer freely spin.
    • If the scroll wheel is still not fixed, you may need to readjust the spring into the cavity again (see Step 5).
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Karmit Dandona
405 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S2-G2, Andersen Winter 2020 UC Davis, Team S2-G2, Andersen Winter 2020 üyesi
UCD-ANDERSEN-W20S2G2
4 Üyeler
2 adet Kılavuz yazıldı
9Kılavuz Yorumları
Great tutorial. I thought I needed to buy another one. With this I managed to fix it under 2 minutes. Thanks! :)
StopShop GSM - Yanıt
Excellent instructions, I searched the web for days looking for the solution. I could not determine if it was software or hardware, the mouse wheel has always spun free, no clicking. After following your instructions, it clicks when I scroll and the spontaneous jumping is gone. Thanks a million!
Bob Weenig - Yanıt
Fantastic instructions! I was struggling to find out how the spring should be placed for the proper ratcheting behavior. This walk-through got me there in less than a minute. Thank you very much!
Sean Smith - Yanıt
Is there any way to replace the spring if lost?
Connor - Yanıt
Thanks so much for the great tutorial. The pictures really helped.
Maureen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 44
Son 30 gün: 189
Her zaman: 10,885
