Ana içeriğe geç
Logitech M331 Disassembly
garfieldknight
garfieldknight ve 5 diğer katkıda bulunanlar
En son June 24, 2024 tarihinde güncellendi
15 dakika
Kolay
Topluluk-Katkılı Kılavuz
This guide is to help you disassemble Logitech M331/M330 mouse and clean the mouse wheel.
Neye ihtiyacın var
  1. Logitech M331 Disassembly, Mouse: adım 1, 1 resimden 1.
    • Carefully detach the upper case and the lower case of the mouse by holding the lower case and lifting the upper case up and then pulling it backward.
  2. Logitech M331 Disassembly: adım 2, 1 resimden 1.
    • Carefully detach the upper case and the lower case of the mouse by holding the lower case and sliding the upper case forward.
    (Sorry about my english :))
    And there is one little Lock down right. You can unlock it with a flat screwdriver.
    Bane - Yanıt
  3. Logitech M331 Disassembly: adım 3, 1 resimden 1.
    • Unscrew the screw in the purple circle and unfasten the plastic pins in blue circles to remove the board from the plastic cover.
  4. Logitech M331 Disassembly: adım 4, 2 resimden 1. Logitech M331 Disassembly: adım 4, 2 resimden 2.
    • To disassemble the upper case of the mouse, detach the plastic pins located in the blue circles. The two pins located in purple circles will be automatically unfastened once the four blue pins are detached.
    • To disassemble the light propagator, detach the small plastic pin at the bottom of the mouse case and light propagator connection.
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
garfieldknight
1.088 İtibar
2 adet Kılavuz yazıldı
8Kılavuz Yorumları
first time using ifixit
this was just what i needed thanks!
Prentiss Johnson - Yanıt
Thanks for the guide! I was able to clean the scroll wheel properly and fixed the annoying inaccurate scroll issue.
Gabriel Louie Cubelo - Yanıt
Exactly what I needed, a clear and direct guide. Thank you so much!
Zıbın Zıbınoğlu - Yanıt
Finally my mouse-wheel has stopped ghost scrolling, I used to have this problem where when I scrolled down and up it would go the opposite direction, at first I thought it was a bug but turns out on my other wired logitech mouse, it worked normally.
Upon following this instruction manual (A++) I managed to put some WD40 in the mouse wheel scrolling part, from the inside (not the wheel but the thing it’s attached to) and scrolled it a couple of times, now it works normally :)
Thanks to the author!
TAY CHU TSE ANDREW - Yanıt
Thanks, cleaning up my M331 and put nachi tape on right-mouse-button so it works again (after it deform slightly).
yayanm 1k - Yanıt
Scroll wheel for my mouse has become sticky , is not smooth while scrolling…. Are there replacement scroll wheels available ?
Don’t you think, given the resource crunch on the planet - companies should offer spare parts, rather than use and throw ?
Agasthya - Yanıt
My mouse is not working even after disassembling and then reassembling. I tried checking what the problem is, but even though I tried different batteries, the mouse wouldn’t start. Can someone help?
Harshil Dari - Yanıt
Thanks, and FYI that works exacly for the M330 too!
schnurlos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 63
Son 30 gün: 279
Her zaman: 14,869
