Ana içeriğe geç
Logitech M515 (Couch) Mouse
Anna Sweetnam
Anna Sweetnam ve başka bir katkıda bulunan
En son January 26, 2025 tarihinde güncellendi
5 dakika
Çok kolay
Topluluk-Katkılı Kılavuz
Taking the outer shell off is very easy and all of the internals are visible when it is removed.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Logitech M515 (Couch) Mouse, Removing the outer shell: adım 1, 1 resimden 1.
    • Remove the battery hatch and batteries.
  2. Logitech M515 (Couch) Mouse: adım 2, 1 resimden 1.
    • Remove the single Phillips screw located between the battery sockets.
    I used this guide to open my Logitech M-RCQ142 (that looks almost the same). Logitech changed the one screw-system to four screws located in the same place, so this guide worked perfect. Thanks for sharing!
    WillemPirquin - Yanıt
  3. Logitech M515 (Couch) Mouse: adım 3, 1 resimden 1.
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
    doesn't go deep enough. need to fix right switch. part numbers are required.
    Lewayne Gragert - Yanıt
    I doubt you can get parts for this, it's not a high ticket item.
    Anna Sweetnam - Yanıt
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Anna Sweetnam
262 İtibar
1 Kılavuz yazıldı
4Kılavuz Yorumları
I got to step 3. where is step 4?
hawaii50 - Yanıt
What are you trying to do? All of the innards are available once step 3 is complete.
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Yanıt
M545 works similarly btw
Adri Idzwan Mansor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 5,189
