Logitech MX Master 2S Mouse Feet Replacement
Giriş
1. adıma gitUse this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech MX Master 2S mouse.
While it’s possible to cleanly remove the feet, you may need replacements if one rips or separates from its adhesive pad.
Neye ihtiyacın var
Tamir Seti
Bu kit, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
Heat an iOpener and apply it to the mouse feet for about two minutes.
Insert an opening pick between the left foot and the lower case.
Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers or your fingers to remove the mouse foot.
Repeat the previous two steps for the three remaining feet.
Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
Peel your new mouse feet away from their adhesive liners and press them firmly into place.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Are those feet the same shape as the ones in the original MX Master?
