Ana içeriğe geç
Logitech MX Master 3S Top Shell Replacement
Neye ihtiyacın var
    1. Logitech MX Master 3S Top Shell Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 3.
      • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
      • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
      • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
      • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
      • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
      • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
      • The information sticker adhesive may soften during this step, but you don't need to remove it.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech MX Master 3S Top Shell Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 3.
      • Slide an opening pick under an edge of the left mouse foot.
      • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
      • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
      • If the foot feels stuck, apply more heat before continuing.
      • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
      • Peel up and remove the left mouse foot.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech MX Master 3S Top Shell Replacement, Remove the remaining feet: adım 3, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Remove the remaining feet: adım 3, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Remove the remaining feet: adım 3, 3 resimden 3.
      • Repeat the previous two steps for the three remaining feet.
      • The front foot doesn't cover any screws—if you're only removing the mouse feet to open up the mouse, you don't need to remove this foot.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech MX Master 3S Top Shell Replacement, Reassembly information: adım 4, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Reassembly information: adım 4, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Reassembly information: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      • If the adhesive separated from the foot:
      • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
      • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
      • For installing new mouse feet or reusing your old ones:
      • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free or microfiber cloth. Allow the surface to dry completely.
      • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech MX Master 3S Top Shell Replacement, Unfasten the lower case: adım 5, 1 resimden 1.
      • Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the bottom half of the lower case.
      • Use a T5 Torx driver to remove the one 4.2 mm‑long screw securing the top half of the lower case.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech MX Master 3S Top Shell Replacement, Release the left clips: adım 6, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Release the left clips: adım 6, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Release the left clips: adım 6, 3 resimden 3.
      • Insert your opening pick into the seam between the thumb rest and the lower case.
      • Slide your pick right, towards the rear of the upper shell and pry upward to release the left clips.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech MX Master 3S Top Shell Replacement, Release the right clips: adım 7, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement, Release the right clips: adım 7, 2 resimden 2.
      • Gently pry the upper shell and lower case apart to release the clips on the right side of the mouse.
      • Don't try to fully remove the top shell just yet—another clip and a delicate cable connect the upper shell to the lower case.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech MX Master 3S Top Shell Replacement, Release the final clip: adım 8, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Release the final clip: adım 8, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Release the final clip: adım 8, 3 resimden 3.
      • Lay your mouse down onto your work surface, making sure none of the clips re-engage.
      • Grasp the upper shell and partially lift up the right edge.
      • Pull the upper shell up and back to release the final clip and separate the upper shell from the lower case.
      • Still keep the two halves close together—a cable is still tethered to the upper shell.
      • To reinstall the upper shell, slide the front edge into place first, then press down around the perimeter of the upper shell to engage the remaining clips.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech MX Master 3S Top Shell Replacement, Reposition the upper shell: adım 9, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Reposition the upper shell: adım 9, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Reposition the upper shell: adım 9, 3 resimden 3.
      • Be careful not to strain the cable connecting the upper shell to the lower case.
      • Lift the upper shell away from the lower case and lay it to the right of the mouse.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech MX Master 3S Top Shell Replacement, Disconnect the interconnect cable: adım 10, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Disconnect the interconnect cable: adım 10, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Disconnect the interconnect cable: adım 10, 3 resimden 3.
      • Use the flat end of a spudger to gently lift up the sliding lock on the interconnect cable socket.
      • Slide the cable straight out of its socket on the motherboard.
      • During reassembly, insert the cable into the socket with its blue tab facing out, then push down the sliding lock to secure the cable.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech MX Master 3S Top Shell Replacement, Remove the upper shell: adım 11, 1 resimden 1.
      • Remove the upper shell from the lower case.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech MX Master 3S Top Shell Replacement, Disconnect the horizontal scroll wheel assembly: adım 12, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Disconnect the horizontal scroll wheel assembly: adım 12, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Disconnect the horizontal scroll wheel assembly: adım 12, 3 resimden 3.
      • Lay the top shell upside down on your work surface.
      • Use the flat end of a spudger to push out the plastic latch on the connector near the right side of the shell.
      • You should feel the latch pop into the unlocked position. Don't push too far, or the latch may come completely off the connector.
      • Use tweezers or your fingers to gently pull the cable straight up and out of its socket.
      • The cable should come out easily. If you feel any resistance, push the latch out a little more and try again.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech MX Master 3S Top Shell Replacement, Unfasten the horizontal scroll wheel assembly: adım 13, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement, Unfasten the horizontal scroll wheel assembly: adım 13, 2 resimden 2.
      • Use a Phillips screwdriver to remove the three 3.5 mm‑long screws securing the gesture button board assembly to the underside of the thumb rest.
      • Don't remove the two smaller screws in the board itself.
      FixBot'a Sor
      Yorum Ekle
    3. Logitech MX Master 3S Top Shell Replacement, Unclip the gesture button board: adım 14, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Unclip the gesture button board: adım 14, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Unclip the gesture button board: adım 14, 3 resimden 3.
      • Don't try to fully remove the gesture button board assembly. It'll be removed together with the horizontal scroll wheel assembly in a few steps.
      • Push down the outer edge of the thumb rest to unclip the right edge of the gesture button board assembly.
      • Lift the assembly off its alignment posts and pull it towards the center of the shell.
      FixBot'a Sor
      Yorum Ekle
    4. Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly screws: adım 15, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly screws: adım 15, 2 resimden 2.
      • Use a Phillips screwdriver to remove the two 3.5 mm‑long screws securing the horizontal scroll wheel assembly.
      FixBot'a Sor
      Yorum Ekle
    5. Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly: adım 16, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly: adım 16, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, Remove the horizontal scroll wheel assembly: adım 16, 3 resimden 3.
      • Removing the horizontal scroll wheel assembly is tricky and may take a few tries—be patient and work slowly.
      • Firmly secure the top shell with one hand.
      • Use your free hand to rotate the horizontal scroll wheel assembly away from the shell and lift to remove it.
      • During reassembly:
      • Make sure the cables in the center of the shell are out of the way so they don't get trapped under the horizontal scroll wheel assembly.
      • Put the assembly back into place so the horizontal scroll wheel and side buttons go into their slots and the plastic housing's circular cutouts go over their pegs.
      FixBot'a Sor
      Yorum Ekle
    6. Logitech MX Master 3S Top Shell Replacement, Remove the left and right click buttons: adım 17, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement, Remove the left and right click buttons: adım 17, 2 resimden 2.
      • Use a Phillips screwdriver to remove the three 3.1 mm‑long screws securing the left and right click buttons.
      FixBot'a Sor
      Yorum Ekle
    7. Logitech MX Master 3S Top Shell Replacement: adım 18, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement: adım 18, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement: adım 18, 3 resimden 3.
      • Be very careful not to lose the two small springs on either side of the scroll wheel cutout. Otherwise, the buttons won't click properly when the mouse is reassembled.
      • Use your fingers to remove the left and right click buttons.
      FixBot'a Sor
      Yorum Ekle
    8. Logitech MX Master 3S Top Shell Replacement, Remove the scroll mode board: adım 19, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement, Remove the scroll mode board: adım 19, 2 resimden 2.
      • Use a Phillips screwdriver to remove the three 3.5 mm‑long screws securing the scroll mode button board.
      FixBot'a Sor
      Yorum Ekle
    9. Logitech MX Master 3S Top Shell Replacement: adım 20, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement: adım 20, 2 resimden 2.
      • Use your fingers to gently lift and remove the scroll mode button board.
      FixBot'a Sor
      Yorum Ekle
    10. Logitech MX Master 3S Top Shell Replacement, Remove the scroll mode button: adım 21, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement, Remove the scroll mode button: adım 21, 2 resimden 2.
      • Use a Phillips screwdriver to remove the 3.1 mm‑long screw securing the scroll mode button.
      FixBot'a Sor
      Yorum Ekle
    11. Logitech MX Master 3S Top Shell Replacement: adım 22, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement: adım 22, 2 resimden 2.
      • Use tweezers or your fingers to lift and remove the scroll mode button.
      FixBot'a Sor
      Yorum Ekle
    12. Logitech MX Master 3S Top Shell Replacement, Remove the battery status indicator: adım 23, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement, Remove the battery status indicator: adım 23, 2 resimden 2.
      • Use a Phillips screwdriver to remove the 3.5 mm‑long screw securing the battery status indicator.
      FixBot'a Sor
      Yorum Ekle
    13. Logitech MX Master 3S Top Shell Replacement: adım 24, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement: adım 24, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement: adım 24, 3 resimden 3.
      • Use tweezers or your fingers to lift the battery status indicator off its post and remove it.
      • During reassembly, insert the indicator into its slot on the edge of the shell and then lower it into place so the screw hole goes onto its post.
      FixBot'a Sor
      Yorum Ekle
    14. Logitech MX Master 3S Top Shell Replacement, Remove the battery status indicator housing: adım 25, 2 resimden 1. Logitech MX Master 3S Top Shell Replacement, Remove the battery status indicator housing: adım 25, 2 resimden 2.
      • Use a Phillips screwdriver to remove the 3.4 mm‑long screw securing the battery status indicator housing.
      FixBot'a Sor
      Yorum Ekle
    15. Logitech MX Master 3S Top Shell Replacement: adım 26, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement: adım 26, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement: adım 26, 3 resimden 3.
      • Use the flat end of a spudger to lift the battery status indicator housing off its post and unclip it.
      • If you're having trouble, use a spudger to push in the housing's small clip.
      • Remove the housing.
      • During reassembly, push the housing into its cutout until it clicks into place.
      FixBot'a Sor
      Yorum Ekle
    16. Logitech MX Master 3S Top Shell Replacement, You're left with the top shell: adım 27, 3 resimden 1. Logitech MX Master 3S Top Shell Replacement, You're left with the top shell: adım 27, 3 resimden 2. Logitech MX Master 3S Top Shell Replacement, You're left with the top shell: adım 27, 3 resimden 3.
      • You're left with the top shell.
      • During reassembly, you'll need to transfer the parts you removed from the old shell to the new one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Spencer Day
198.323 İtibar
1.243 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
51.206 adet Kılavuz yazıldı
12Kılavuz Yorumları
Hello. Interesting guide. Where can I buy the top shell? I can't see any option to purchase it. Thanks.
Alan Naïve - Yanıt Paylaş
@alannaive I know I'm late, but this might still interest someone: I don't think you can buy this as a replacement part, but here are very good CAD files for it to 3D-Print the parts. Might be worth to outsource the print if you can't/don't want to deal with that yourself. I've seen very cool transparent custom shells!
Damien - Yanıt Paylaş
For anyone here with the clicks being less responsive after using it for a while (I used it for a few years before this started happening), I found that after removing the top shell and getting to the switches, and clicking the switches with isopropyl alcohol cotton swab for several times (loosening the dirt between the switch button and the switch body) and drying it, and reconnecting it worked relatively well.
Jun Sung Kim - Yanıt Paylaş
Thank you so much, this is exactly what i was here for.
Dijo Mathews - Yanıt Paylaş
Hi, this guide is great, but where can we get a replacement shell?
Chris Jung - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 67
Son 7 gün: 507
Son 30 gün: 2,239
Her zaman: 44,101
