Ana içeriğe geç
Logitech Signature M650 L Scroll Wheel Assembly Replacement
Neye ihtiyacın var
  1. Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: adım 1, 3 resimden 1. Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: adım 1, 3 resimden 2. Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: adım 1, 3 resimden 3.
    • Slide the battery compartment cover downward and lift it away from the mouse.
    FixBot'a Sor
  2. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the AA battery from the battery compartment.
    FixBot'a Sor
  3. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 3, 2 resimden 1. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 3, 2 resimden 2.
    • Remove the USB receiver from its storage slot inside the battery compartment.
    FixBot'a Sor
  4. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the two screws securing the internal frame.
    FixBot'a Sor
  5. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 5, 2 resimden 1. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 5, 2 resimden 2.
    • Gently lift the top shell away from the mouse body.
    • Do not remove it completely, as it is still connected to the base by a cable.
    FixBot'a Sor
  6. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the two screws securing the scroll wheel assembly.
    FixBot'a Sor
  7. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 7, 2 resimden 1. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 7, 2 resimden 2.
    • Lift the scroll wheel assembly out of the mouse and install the replacement assembly in the same position.
    FixBot'a Sor
  8. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 8, 1 resimden 1.
    • Replace the two Phillips #000 screws to secure the scroll wheel assembly.
    FixBot'a Sor
  9. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 9, 1 resimden 1.
    • Align the top shell with the base and press down along the edges until it snaps into place.
    FixBot'a Sor
  10. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 10, 1 resimden 1.
    • Use a Phillips #000 screwdriver to reinstall the two internal screws.
    FixBot'a Sor
  11. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 11, 3 resimden 1. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 11, 3 resimden 2. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 11, 3 resimden 3.
    • Insert the AA battery, reinstall the USB receiver, and slide the battery compartment cover back into place.
    FixBot'a Sor
  12. Logitech Signature M650 L Scroll Wheel Assembly Replacement: adım 12, 1 resimden 1.
    • Your mouse is now fully reassembled.
    FixBot'a Sor
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 46
Her zaman: 82
