Ana içeriğe geç
Logitech Signature Slim Solar+ Feet Replacement
Neye ihtiyacın var
  1. Logitech Signature Slim Solar+ Feet Replacement, Prepare your keyboard for disassembly: adım 1, 2 resimden 1. Logitech Signature Slim Solar+ Feet Replacement, Prepare your keyboard for disassembly: adım 1, 2 resimden 2.
    • Slide the keyboard's power switch into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface may scratch the keyboard, place a soft towel under it.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Signature Slim Solar+ Feet Replacement: adım 2, 3 resimden 1. Logitech Signature Slim Solar+ Feet Replacement: adım 2, 3 resimden 2. Logitech Signature Slim Solar+ Feet Replacement: adım 2, 3 resimden 3.
    • Insert the point of a spudger under an end of the foot.
    • Slide the spudger underneath the foot and lift until you can grip it with your fingers.
    • Peel the foot up and remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: adım 3, 3 resimden 1. Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: adım 3, 3 resimden 2. Logitech Signature Slim Solar+ Feet Replacement, Install a replacement foot: adım 3, 3 resimden 3.
    • Remove a replacement foot from its backing and firmly press it into place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Arthur Shi
341.710 İtibar
906 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 330
