Ana içeriğe geç
Logitech UE Boombox Tweeter Speaker Replacement
Neye ihtiyacın var
  1. Logitech UE Boombox Tweeter Speaker Replacement, Speaker Grille: adım 1, 2 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement, Speaker Grille: adım 1, 2 resimden 2.
    • Use a metal spudger to pry open the power button cover.
    • Once the power button cover is slightly opened, use your fingers to remove the power button cover.
  2. Logitech UE Boombox Tweeter Speaker Replacement: adım 2, 3 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 2, 3 resimden 2. Logitech UE Boombox Tweeter Speaker Replacement: adım 2, 3 resimden 3.
    • Press firmly on the end of the latch and pull the two-wire connector away from the base to separate.
  3. Logitech UE Boombox Tweeter Speaker Replacement: adım 3, 3 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 3, 3 resimden 2. Logitech UE Boombox Tweeter Speaker Replacement: adım 3, 3 resimden 3.
    • Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
  4. Logitech UE Boombox Tweeter Speaker Replacement: adım 4, 3 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 4, 3 resimden 2. Logitech UE Boombox Tweeter Speaker Replacement: adım 4, 3 resimden 3.
    • Lightly, pry up on each side of the black band connector lock using your fingertips.
    • Once unlocked, pull straight up on the connector to remove.
  5. Logitech UE Boombox Tweeter Speaker Replacement: adım 5, 2 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the five black 14mm Phillips #2 screws from the black plastic side panel.
    • Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the black plastic screw panel from the boombox.
  6. Logitech UE Boombox Tweeter Speaker Replacement: adım 6, 2 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 6, 2 resimden 2.
    • On the opposite side of the device, pry open the volume rocker with a metal spudger.
    • Remove the panel with your fingers once the volume rocker is slightly opened.
  7. Logitech UE Boombox Tweeter Speaker Replacement: adım 7, 3 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 7, 3 resimden 2. Logitech UE Boombox Tweeter Speaker Replacement: adım 7, 3 resimden 3.
    • Remove the one silver16 mm Phillips #2 screw from the black plastic side panel.
    • Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
  8. Logitech UE Boombox Tweeter Speaker Replacement: adım 8, 2 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 8, 2 resimden 2.
    • Firmly press on the end of the latch and pull the two-wire connector away from the base.
  9. Logitech UE Boombox Tweeter Speaker Replacement: adım 9, 2 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 9, 2 resimden 2.
    • Pull up on the aluminum boombox handle to remove.
  10. Logitech UE Boombox Tweeter Speaker Replacement: adım 10, 2 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 10, 2 resimden 2.
    • Use a metal spudger to pry the rubber base apart from the aluminum grille.
  11. Logitech UE Boombox Tweeter Speaker Replacement: adım 11, 2 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 11, 2 resimden 2.
    • Pull the rubber base away from the boombox.
  12. Logitech UE Boombox Tweeter Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • There should be a total of eight screws removed in this step.
  13. Logitech UE Boombox Tweeter Speaker Replacement: adım 13, 3 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 13, 3 resimden 2. Logitech UE Boombox Tweeter Speaker Replacement: adım 13, 3 resimden 3.
    • Pull vertically on the speaker grille to remove it from the boombox.
  14. Logitech UE Boombox Tweeter Speaker Replacement, Tweeter Speaker: adım 14, 3 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement, Tweeter Speaker: adım 14, 3 resimden 2. Logitech UE Boombox Tweeter Speaker Replacement, Tweeter Speaker: adım 14, 3 resimden 3.
    • Remove the fifteen 13.0 mm Phillips #2 screws from the side of the device containing two speakers.
    • Separate the two halves by gently pulling them apart.
  15. Logitech UE Boombox Tweeter Speaker Replacement: adım 15, 1 resimden 1.
    • Locate the two tweeter speakers.
    • One tweeter speaker is adjacent to primary speaker and the other is below the motherboard.
  16. Logitech UE Boombox Tweeter Speaker Replacement: adım 16, 1 resimden 1.
    • Remove the two 7.0 mm screws Phillips #2.
  17. Logitech UE Boombox Tweeter Speaker Replacement: adım 17, 2 resimden 1. Logitech UE Boombox Tweeter Speaker Replacement: adım 17, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using flat-head Tweezers lift tweeter speaker at an angle by the black connecting wire.
    • Desolder the black connecting wire using the Soldering Iron.
    • Soldering Iron will be hot and surrounding plastic can easily be damaged.
    • For soldering help, check out the How to Solder and Desolder Connections guide.
  18. Logitech UE Boombox Tweeter Speaker Replacement: adım 18, 1 resimden 1.
    • Hold the tweeter speaker by the newly disconnected end using flat-head Tweezers.
    • Simultaneously unsolder the thin silver wire using the Soldering Iron while lifting tweeter speaker away from the device using flat-head Tweezers.
  19. Logitech UE Boombox Tweeter Speaker Replacement: adım 19, 1 resimden 1.
    • Remove the two 7.0 mm screws with a Phillips #2.
  20. Logitech UE Boombox Tweeter Speaker Replacement: adım 20, 1 resimden 1.
    • Unsolder the black connecting wire using Soldering Iron.
  21. Logitech UE Boombox Tweeter Speaker Replacement: adım 21, 1 resimden 1.
    • Hold tweeter speaker by newly disconnected end using flat-head tweezers.
    • Simultaneously unsolder the thin silver connecting wire using soldering iron while lifting tweeter speaker away from device using flat-head tweezers.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Wesley Kamau
224 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-1, Bruce Fall 2016 CSU Fullerton, Team 1-1, Bruce Fall 2016 üyesi
CSUF-BRUCE-F16S1G1
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Could you recommend anywhere to find the correct replacement tweeters & drivers?
Ted Glasgow - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 738
