Ana içeriğe geç
Logitech UE Megaboom 4 Battery Replacement
Neye ihtiyacın var
  1. Logitech UE Megaboom 4 Battery Replacement, Battery: adım 1, 3 resimden 1. Logitech UE Megaboom 4 Battery Replacement, Battery: adım 1, 3 resimden 2. Logitech UE Megaboom 4 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Flip your speaker upside down so the charging port side is faced upwards.
    • Take a metal spudger in between the rubber bottom and the mesh case.
    • Work your way around the base of the speaker until the top separates from the case of the speaker.
    • This will take force.
    • Use the metal spudger carefully. Improper use may lead to injury.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech UE Megaboom 4 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the bottom of the speaker and place it off to the side.
    • Once the glued seal is broken you will be able to pull it off with your hands.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech UE Megaboom 4 Battery Replacement: adım 3, 3 resimden 1. Logitech UE Megaboom 4 Battery Replacement: adım 3, 3 resimden 2. Logitech UE Megaboom 4 Battery Replacement: adım 3, 3 resimden 3.
    • Push with your thumbs on the two plastic pieces on the inside of your speaker.
    • The inside components will begin to slide out of the top from the mesh casing.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech UE Megaboom 4 Battery Replacement: adım 4, 1 resimden 1.
    • The case and internal components of your speaker should now be separated.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech UE Megaboom 4 Battery Replacement: adım 5, 3 resimden 1. Logitech UE Megaboom 4 Battery Replacement: adım 5, 3 resimden 2. Logitech UE Megaboom 4 Battery Replacement: adım 5, 3 resimden 3.
    • Pull the battery out with your fingers.
    • When pulling the battery out, you may need to wiggle it a little bit or use a rubber grip on your fingers.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech UE Megaboom 4 Battery Replacement: adım 6, 1 resimden 1.
    • When installing the new battery, ensure that the battery connector aligns with the connector on the speaker so they don't get damaged.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
ifixt it doesn't have the battery replacement version for the Ultimate Ears - MEGABOOM 4 and only show replacement battery for older model and I think this get confuse for new users in the repair world
Gio Ortegini - Yanıt Paylaş
Hi Gio,
Thanks for pointing this out! We’ve removed the link to the incorrect battery and appreciate your help keeping the guide accurate.
Sarah Westberg - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 78
Her zaman: 1,003
