Ana içeriğe geç
Logitech UE Megaboom 4 Charging Port Replacement
Neye ihtiyacın var
  1. Logitech UE Megaboom 4 Charging Port Replacement, Outer Case: adım 1, 3 resimden 1. Logitech UE Megaboom 4 Charging Port Replacement, Outer Case: adım 1, 3 resimden 2. Logitech UE Megaboom 4 Charging Port Replacement, Outer Case: adım 1, 3 resimden 3.
    • Flip your speaker upside down so the charging port side is faced upwards.
    • Place the end of a metal spudger in between the rubber bottom and the mesh case.
    • Work your way around the base of the speaker until the top separates from the case of the speaker.
    • This will take force.
    • Use the metal spudger carefully. Improper use may lead to injury.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech UE Megaboom 4 Charging Port Replacement: adım 2, 1 resimden 1.
    • Pull the bottom end of the speaker off and place it aside.
    • Once the glued seal is broken you will be able to pull it off with your hands.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech UE Megaboom 4 Charging Port Replacement: adım 3, 3 resimden 1. Logitech UE Megaboom 4 Charging Port Replacement: adım 3, 3 resimden 2. Logitech UE Megaboom 4 Charging Port Replacement: adım 3, 3 resimden 3.
    • Use your thumbs to press the two plastic tabs inside the speaker case and gently push out the internal components.
    • The inside components will begin to slide out of the top from the mesh casing.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech UE Megaboom 4 Charging Port Replacement: adım 4, 1 resimden 1.
    • The internal components of the Logitech UE MegaBoom 4 speaker are now separated from the outer case.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech UE Megaboom 4 Charging Port Replacement, Charging Port: adım 5, 1 resimden 1.
    • Remove the cover from the USB-C charging port end of the device.
    • The port should be visible from the outside.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech UE Megaboom 4 Charging Port Replacement: adım 6, 3 resimden 1. Logitech UE Megaboom 4 Charging Port Replacement: adım 6, 3 resimden 2. Logitech UE Megaboom 4 Charging Port Replacement: adım 6, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the two screws securing the I/O board inside the speaker's end cover.
    • Set the screws aside for reassembly.
    • Remove the black plastic bracket from the top of the I/O board.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech UE Megaboom 4 Charging Port Replacement: adım 7, 1 resimden 1.
    • Remove the board with the charging port from the inside cover.
    • Take note of the charging port placement for reassembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2Kılavuz Yorumları
Hi, where dit you find the replacement?
Greets
siemen van camp - Yanıt Paylaş
Same question here, wehre did you find the charging board replacement?
cheers
bohemianmarine1 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 360
