Ana içeriğe geç
Logitech UE Megaboom 4 Power Button Board Replacement
Neye ihtiyacın var
  1. Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: adım 1, 3 resimden 1. Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: adım 1, 3 resimden 2. Logitech UE Megaboom 4 Power Button Board Replacement, Power Button Board: adım 1, 3 resimden 3.
    • Place the end of a metal spudger in the seam between the top cover and outer case of the speaker. Work your way around the seam of the cover to loosen it.
    • This will take force as it is glued down with the waterproofing sealant.
    • Be careful when using the metal spudger. It is sharp and can cause damage to your device and yourself.
    • Separate the top cover of the speaker from the case.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech UE Megaboom 4 Power Button Board Replacement: adım 2, 2 resimden 1. Logitech UE Megaboom 4 Power Button Board Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove four screws from the underside of the top cover of the speaker.
    • Remove the black bracket covering the button board.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech UE Megaboom 4 Power Button Board Replacement: adım 3, 1 resimden 1.
    • Remove the circuit board from the cap.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 279
