Ana içeriğe geç
Logitech Webcam Pro 9000 Camera Replacement
Neye ihtiyacın var
    1. Logitech Webcam Pro 9000 Camera Replacement, Front and Back Cover: adım 1, 2 resimden 1. Logitech Webcam Pro 9000 Camera Replacement, Front and Back Cover: adım 1, 2 resimden 2.
      • Remove the two 8 mm Phillips #0 screws on the back cover.
      • The motherboard connects the two covers together. DO NOT separate the two yet.
      • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech Webcam Pro 9000 Camera Replacement: adım 2, 2 resimden 1. Logitech Webcam Pro 9000 Camera Replacement: adım 2, 2 resimden 2.
      • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
      • DO NOT detach the wire connecting the motherboard to the front cover.
      FixBot'a Sor
      Yorum Ekle
    1. Logitech Webcam Pro 9000 Camera Replacement, Camera: adım 3, 1 resimden 1.
      • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Logitech Webcam Pro 9000 Camera Replacement: adım 4, 3 resimden 1. Logitech Webcam Pro 9000 Camera Replacement: adım 4, 3 resimden 2. Logitech Webcam Pro 9000 Camera Replacement: adım 4, 3 resimden 3.
      • Remove the camera from the motherboard by desoldering the two connections as shown.
      • Follow this link to learn how to properly solder and desolder your parts.
      FixBot'a Sor
      Yorum Ekle
Sonuç
nieko
63 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G34
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 51
Her zaman: 2,889
