Ana içeriğe geç
Logitech Webcam Pro 9000 Motherboard Replacement
Neye ihtiyacın var
  1. Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: adım 1, 2 resimden 1. Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: adım 1, 2 resimden 2.
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
    FixBot'a Sor
    Yorum Ekle
  2. Logitech Webcam Pro 9000 Motherboard Replacement: adım 2, 2 resimden 1. Logitech Webcam Pro 9000 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
    FixBot'a Sor
    Yorum Ekle
  3. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: adım 3, 3 resimden 1. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: adım 3, 3 resimden 2. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: adım 3, 3 resimden 3.
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
    FixBot'a Sor
    Yorum Ekle
  4. Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: adım 4, 2 resimden 1. Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: adım 4, 2 resimden 2.
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: adım 5, 2 resimden 1. Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
    FixBot'a Sor
    Yorum Ekle
  6. Logitech Webcam Pro 9000 Motherboard Replacement: adım 6, 2 resimden 1. Logitech Webcam Pro 9000 Motherboard Replacement: adım 6, 2 resimden 2.
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
    FixBot'a Sor
    Yorum Ekle
  7. Logitech Webcam Pro 9000 Motherboard Replacement, Camera: adım 7, 1 resimden 1.
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Logitech Webcam Pro 9000 Motherboard Replacement: adım 8, 3 resimden 1. Logitech Webcam Pro 9000 Motherboard Replacement: adım 8, 3 resimden 2. Logitech Webcam Pro 9000 Motherboard Replacement: adım 8, 3 resimden 3.
    • Remove the camera from the motherboard by desoldering the two connections as shown.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cory Davis
236 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S12G34
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 2,597
