Ana içeriğe geç
Lorex LW2744 Wi-Fi Antenna Replacement
Neye ihtiyacın var
  1. Lorex LW2744 Wi-Fi Antenna Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the 5.0mm screw using the Phillips #0 head screwdriver.
  2. Lorex LW2744 Wi-Fi Antenna Replacement: adım 2, 1 resimden 1.
    • Insert metal spudger as shown in the picture. Move spudger along to the other side until both snaps come loose.
  3. Lorex LW2744 Wi-Fi Antenna Replacement: adım 3, 1 resimden 1.
    • Picture shows the removed battery cover.
  4. Lorex LW2744 Wi-Fi Antenna Replacement: adım 4, 1 resimden 1.
    • Slide the battery out by pulling on one of two plastics tabs.
  5. Lorex LW2744 Wi-Fi Antenna Replacement, Wi-Fi Antenna: adım 5, 1 resimden 1.
    • Remove the remaining five 6.0 mm Phillips #0 screws.
  6. Lorex LW2744 Wi-Fi Antenna Replacement: adım 6, 1 resimden 1.
    • Use the spudger to remove the back cover. Insert the spudger between the back and front cover. Once inserted, you will need to move it around the perimeter to release the snaps holding it together.
  7. Lorex LW2744 Wi-Fi Antenna Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Once back cover is removed, the speaker wire will need to be removed. Use tweezers to remove wire.
  8. Lorex LW2744 Wi-Fi Antenna Replacement: adım 8, 1 resimden 1.
    • Begin by heating the exposed end of the grey lead with the tip of a soldering iron while simultaneously pulling the lead away from the connection, using tweezers to grasp the lead by the insulation.
    • For more information on soldering, check out this repair guide: iFixit Soldering
Sonuç
Yancey Crase
217 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Harley Spring 2018 IUPUI, Team S1-G4, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G4
7 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 279
