Ana içeriğe geç
M3D Micro Nozzle Replacement
Neye ihtiyacın var
  1. M3D Micro Nozzle Replacement, Fan: adım 1, 3 resimden 1. M3D Micro Nozzle Replacement, Fan: adım 1, 3 resimden 2. M3D Micro Nozzle Replacement, Fan: adım 1, 3 resimden 3.
    • To release the x-rods, pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks.
  2. M3D Micro Nozzle Replacement: adım 2, 3 resimden 1. M3D Micro Nozzle Replacement: adım 2, 3 resimden 2. M3D Micro Nozzle Replacement: adım 2, 3 resimden 3.
    • Slide the tracks off the second slider and remove the printer head and x-tracks from the center of the printer. To remove the front cover of the print head, firmly grip the cover and gently pull it off.
  3. M3D Micro Nozzle Replacement: adım 3, 2 resimden 1. M3D Micro Nozzle Replacement: adım 3, 2 resimden 2.
    • Disconnect the red and black wires at the white connector. They should easily separate.
  4. M3D Micro Nozzle Replacement: adım 4, 3 resimden 1. M3D Micro Nozzle Replacement: adım 4, 3 resimden 2. M3D Micro Nozzle Replacement: adım 4, 3 resimden 3.
    • The fan is held loosely in place at the base of the printer head. Use a metal spudger to gently pry it out of the printer head.
  5. M3D Micro Nozzle Replacement: adım 5, 1 resimden 1.
    • Pull the fan all the way out of the printer head.
  6. M3D Micro Nozzle Replacement, Nozzle: adım 6, 2 resimden 1. M3D Micro Nozzle Replacement, Nozzle: adım 6, 2 resimden 2.
    • To remove the nozzle insulation, grip the insulation and pull it up off of the nozzle.
  7. M3D Micro Nozzle Replacement: adım 7, 2 resimden 1. M3D Micro Nozzle Replacement: adım 7, 2 resimden 2.
    • To remove the nozzle, use a 5 mm nut driver to unscrew it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Yuliya Marusyk
285 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Nance Fall 2017 USF Tampa, Team S3-G2, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G2
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Do you know where I can source replacement nozzles for this? M3D doesn't have a store page anymore and none of the "standard" nozzles that I've found look like the longer piece that the m3d uses. The one I'm replacing is completely gummed up and stuck on the heating element, so I'm looking to replace both but can't find a source for parts specifically for this model
Omar Tariq - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 16
Her zaman: 2,894
