Ana içeriğe geç
MNT Reform CPU Module Replacement
Neye ihtiyacın var
  1. MNT Reform CPU Module Replacement, Remove Bottom Plate Screws: adım 1, 1 resimden 1.
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
    FixBot'a Sor
    Yorum Ekle
  2. MNT Reform CPU Module Replacement, Remove Bottom Plate: adım 2, 1 resimden 1.
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
    FixBot'a Sor
    Yorum Ekle
  3. MNT Reform CPU Module Replacement, Remove Battery Cells: adım 3, 2 resimden 1. MNT Reform CPU Module Replacement, Remove Battery Cells: adım 3, 2 resimden 2.
    • Pull out the eight battery cells one by one, and set them aside safely.
    • Do not use a metal tool to remove the batteries. You may accidentally short-circuit the metal pins of the battery holders.
    • When replacing the batteries, pay attention to the polarity! Inserting a cell the wrong way in will damage your device.
    • The circuit board indicates the + and - orientation for each cell.
    FixBot'a Sor
    Yorum Ekle
  4. MNT Reform CPU Module Replacement, Remove Heatsink Screws: adım 4, 1 resimden 1.
    • Remove the following screws securing the heatsink:
    • Four M2×12 Philips screws
    FixBot'a Sor
    Yorum Ekle
  5. MNT Reform CPU Module Replacement, Remove the Heatsink: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Gently pull the heatsink up.
    • Take care not to lose the four cylindrical plastic spacers supporting the heatsink.
    • When replacing the heatsink, remember to place the spacers over the screw holes before screwing down the heatsink. It may be helpful to use tweezers to align the spacers if placing the heatsink on top shifted them.
    • When replacing the heatsink into the laptop, you will need to apply new thermal paste. We have a thermal paste guide that makes replacing the thermal compound easy.
    • If you need to remove the heatsink frequently, it is possible to replace the thermal paste with a 0.5mm thermal pad instead.
    FixBot'a Sor
    Yorum Ekle
  6. MNT Reform CPU Module Replacement, Disconnect CPU Module Ribbon Cable: adım 6, 2 resimden 1. MNT Reform CPU Module Replacement, Disconnect CPU Module Ribbon Cable: adım 6, 2 resimden 2.
    • Gently lift the black tab on the ribbon cable connector, then slide the ribbon cable out.
    FixBot'a Sor
    Yorum Ekle
  7. MNT Reform CPU Module Replacement, Release CPU Module: adım 7, 1 resimden 1.
    • Release the tabs on each side of the CPU module by pulling them at the same time.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up, similarly to a RAM stick on other laptop computers.
    FixBot'a Sor
    Yorum Ekle
  8. MNT Reform CPU Module Replacement, Remove CPU Module: adım 8, 1 resimden 1.
    • Pull the CPU module out of its socket on the motherboard.
    • To avoid damaging its socket on the motherboard, do not excessively lift the free end of the CPU module.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Don't forget to re-apply new thermal paste.
Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
Bir başkası bu kılavuzu tamamladı.
Neelfyn
981 İtibar
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 928
