Ana içeriğe geç
MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement
Neye ihtiyacın var
  1. MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 1. MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 2. MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 3 resimden 3.
    • First, turn off the laptop and make sure it is unplugged from power to avoid injury or damage to your device.
    • Unscrew the 15 screws on the bottom panel of the computer using a Phillips #00 screwdriver. One screw will be hidden under a warranty sticker
    • Gently pry around the back cover off the with a plastic spudger
    • Unplug the battery cable from the motherboard.
    • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
  2. MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement: adım 2, 2 resimden 1. MSI GS63VR 6RF Stealth Pro Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Unscrew the single screw from the Wi-Fi card using a Phillips #00 screwdriver.
    • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
    • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
    • Reconnecting these can be tricky. Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
    • Using tweezers, carefully grab and remove the Wi-Fi card.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
3Kılavuz Yorumları
Is this a msata card or a m.2 card?
keith dragon - Yanıt
Hi, do you know where I can find some new wifi cables? I broke mine (with my WiFi card) and looking to repair it
Best regards
Bastien Allaoui - Yanıt
Hi there , the wifi cable (aux) its not connecting to the card , probaly I have bent it , what problem does it cause because right now I still can use the wifi, and most important thing , where can I buy it and how can change it ? Thanks
Adriano - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 4,614
