Ana içeriğe geç
Mac Mini Mid 2010 AC-In socket repair
Neye ihtiyacın var
    1. Mac Mini Mid 2010 AC-In socket repair, Bottom Cover: adım 1, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair, Bottom Cover: adım 1, 2 resimden 2.
      • Place your thumbs in the depressions cut into the bottom cover.
      • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini Mid 2010 AC-In socket repair: adım 2, 1 resimden 1.
      • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
      • Remove the bottom cover and set it aside.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Mini Mid 2010 AC-In socket repair, Fan: adım 3, 1 resimden 1.
      • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini Mid 2010 AC-In socket repair: adım 4, 1 resimden 1.
      • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
      • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
      FixBot'a Sor
      Yorum Ekle
    3. Mac Mini Mid 2010 AC-In socket repair: adım 5, 1 resimden 1.
      • Lift the fan out of the mini for enough clearance to access its connector.
      • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
      • Remove the fan.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Mini Mid 2010 AC-In socket repair, Cowling: adım 6, 1 resimden 1.
      • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini Mid 2010 AC-In socket repair: adım 7, 1 resimden 1.
      • Lift the cowling from the end nearest the antenna plate.
      • Rotate the cowling away from the outer case and remove it from the mini.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Mini Mid 2010 AC-In socket repair, Antenna Plate: adım 8, 1 resimden 1.
      • Remove the following screws securing the antenna plate to the mini:
      • Two 6.6 mm T8 or T9 Torx screws
      • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini Mid 2010 AC-In socket repair: adım 9, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair: adım 9, 2 resimden 2.
      • Slightly lift the antenna plate from the end closest to the RAM.
      • Carefully pull the antenna plate straight away from the circular rim of the outer case.
      • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
      FixBot'a Sor
      Yorum Ekle
    3. Mac Mini Mid 2010 AC-In socket repair: adım 10, 1 resimden 1.
      • Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
      FixBot'a Sor
      Yorum Ekle
    4. Mac Mini Mid 2010 AC-In socket repair: adım 11, 1 resimden 1.
      • Remove the antenna plate from the mini.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Mini Mid 2010 AC-In socket repair, Logic Board: adım 12, 1 resimden 1.
      • Remove the following three screws:
      • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
      • One 16.2 mm T6 Torx screw
      • One 26 mm T6 Torx standoff
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini Mid 2010 AC-In socket repair: adım 13, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair: adım 13, 2 resimden 2.
      • Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
      FixBot'a Sor
      Yorum Ekle
    3. Mac Mini Mid 2010 AC-In socket repair: adım 14, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair: adım 14, 2 resimden 2.
      • Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
      FixBot'a Sor
      Yorum Ekle
    4. Mac Mini Mid 2010 AC-In socket repair: adım 15, 1 resimden 1.
      • To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
      FixBot'a Sor
      Yorum Ekle
    5. Mac Mini Mid 2010 AC-In socket repair: adım 16, 1 resimden 1.
      • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
      FixBot'a Sor
      Yorum Ekle
    6. Mac Mini Mid 2010 AC-In socket repair: adım 17, 3 resimden 1. Mac Mini Mid 2010 AC-In socket repair: adım 17, 3 resimden 2. Mac Mini Mid 2010 AC-In socket repair: adım 17, 3 resimden 3.
      Bu adımda kullanılan alet:
      Mac mini Logic Board Removal Tool
      • To remove the logic board, two cylindrical rods must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
      • Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
      • If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
      • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
      • Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
      FixBot'a Sor
      Yorum Ekle
    7. Mac Mini Mid 2010 AC-In socket repair: adım 18, 1 resimden 1.
      • Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
      FixBot'a Sor
      Yorum Ekle
    8. Mac Mini Mid 2010 AC-In socket repair: adım 19, 1 resimden 1.
      • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
      • Use a pair of tweezers to disconnect the power cable from the logic board.
      • Pull the power cable connector toward the optical drive opening.
      FixBot'a Sor
      Yorum Ekle
    9. Mac Mini Mid 2010 AC-In socket repair: adım 20, 1 resimden 1.
      • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Mini Mid 2010 AC-In socket repair, Power Supply: adım 21, 1 resimden 1.
      • Remove the 7.9 mm T6 Torx screw securing the power supply and optical drive to the outer case.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini Mid 2010 AC-In socket repair: adım 22, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair: adım 22, 2 resimden 2.
      • Pull the silver metal AC-In socket retainer away from the side of the outer case and remove it from the mini.
      FixBot'a Sor
      Yorum Ekle
    3. Mac Mini Mid 2010 AC-In socket repair: adım 23, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair: adım 23, 2 resimden 2.
      • Rotate the AC-In connector 90 degrees counter-clockwise.
      FixBot'a Sor
      Yorum Ekle
    4. Mac Mini Mid 2010 AC-In socket repair: adım 24, 1 resimden 1.
      • Slide the power supply out of the mini, minding any cables that may get caught.
      FixBot'a Sor
      Yorum Ekle
    1. Mac Mini Mid 2010 AC-In socket repair, Crumbling insulation on AC wires: adım 25, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair, Crumbling insulation on AC wires: adım 25, 2 resimden 2.
      • While opening a Mac Mini 2010 I discovered that the insulation on the short wires connecting the AC-In socket to the power supply was cracked. The "twist" operation to remove the AC-In socket from the case caused the wire insulation to crumble to small pieces. In the end, all the insulation fell off, the wires remained completely bare.
      • Mare sure the Power Supply is not connected to mains AC power while working on it.
      • Discharge the Power Supply before touching the wires by pushing the power button while the AC cable is unplugged then shorting the AC terminals in the plug with a screwdriver.
      • If you don't feel comfortable doing the above, then please purchase a replacement power supply.
      FixBot'a Sor
      Yorum Ekle
    2. Mac Mini Mid 2010 AC-In socket repair, Opening the PSU case: adım 26, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair, Opening the PSU case: adım 26, 2 resimden 2.
      • Follow the Mac mini Mid 2010 Power Supply Replacement guide to get to this point.
      • As the power supply case is made of glued thin plastic I used a flush cutter and a hobby knife to slice back the edges of the case about one inch, in order to get access to the PCB.
      FixBot'a Sor
      Yorum Ekle
    3. Mac Mini Mid 2010 AC-In socket repair, Desoldering the wires: adım 27, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair, Desoldering the wires: adım 27, 2 resimden 2.
      • Peel up all the layers and prop them up (I used a toothpick). De-solder the two wire terminals - you will have to slightly pull down on the wire while melting the solder.
      FixBot'a Sor
      Yorum Ekle
    4. Mac Mini Mid 2010 AC-In socket repair, Cleaning the solder, re-insulate wires: adım 28, 3 resimden 1. Mac Mini Mid 2010 AC-In socket repair, Cleaning the solder, re-insulate wires: adım 28, 3 resimden 2. Mac Mini Mid 2010 AC-In socket repair, Cleaning the solder, re-insulate wires: adım 28, 3 resimden 3.
      • The AC wires actually have a crimped pin-plug on the end. You will have to use flux and soldering wick to clean as much solder from the so they fit back nicely in the original PCB holes.
      • After the solder blobs on the pins are removed, insert two pieces of heat-shrink tubing over the wires and hear them with a lighter/match/candle/hot air gun.
      • Make sure the heat-shrink tubing won't cover the pins at the end of the wires, else you will have difficulties re-soldering them.
      • Also use soldering wick to clean the two holes in the PCB for easier reassembly.
      FixBot'a Sor
      Yorum Ekle
    5. Mac Mini Mid 2010 AC-In socket repair, Re-attaching the wires: adım 29, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair, Re-attaching the wires: adım 29, 2 resimden 2.
      • Solder the now-insulated wires back into their original PCB holes.
      • Make sure the AC plug is positioned as in the 2nd picture ("long tongue" pointing up) or else you will have problems rotating the plug back into the aluminium case grooves.
      FixBot'a Sor
      Yorum Ekle
    6. Mac Mini Mid 2010 AC-In socket repair: adım 30, 2 resimden 1. Mac Mini Mid 2010 AC-In socket repair: adım 30, 2 resimden 2.
      • Use Kapton (Polyimide) high-temperature tape to re-close the PSU case. Depending on the tape, you might have to use your fingernail or a spudger to press on the tape so the adhesive makes good contact with the plastic case.
      • As an extra safety measure, you can add a loop of Kapton tape over one (or both) of the insulated wires. Make the loops very loose, else you will not be able to twist the plug back into the case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Now reassemble the Mac Mini and test it.
Sergiu Partenie
199 İtibar
1 Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
334 Üyeler
6.817 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 496
