Giriş
This unit includes the hard drive, fan, and optical drive.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
16 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
Bir Yorum
great guide, removing the casing at the start requires some force. thanks for posting
