Giriş
Use this guide to remove, strip, and replace the logic board in your Mac mini Late 2014.
Don't forget to apply a new layer of thermal compound before reassembling your Mac mini. Follow our thermal paste guide for instructions on cleaning and preparing the thermal surfaces and applying a new layer of thermal compound.
This guide was made with a Fusion Drive Mac mini, and may have more connectors and components than your model. Don't be alarmed if you're missing a hard drive or SSD connector!
Neye ihtiyacın var
The bottom cover is clipped onto three screw posts.
Pry near, but not right on the screw posts.
Remove the following TR6 screws from the antenna plate:
Three 4.1 mm screws
Three 1.9 mm screws
Remove the two 12 mm T6 screws from the fan.
Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
Bu adımda kullanılan alet:Mac mini Logic Board Removal Tool$4.99
Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
Remove the following screws securing the heat sink to the logic board:
Four 8.6 mm T8 Torx screws
One 2.9 mm T6 Torx screw
Remove the following T6 Torx screws from the I/O port antenna cables:
Three 2.8 mm screws with washers
One 3.4 mm screw
One 2.7 mm screw
Remove the following T6 Torx screws securing the speaker to the logic board:
One 3.6 mm screw
One 3.6 mm large headed screw
Remove the 2.7 mm T5 screw securing the AirPort card.
Lift the free end of the AirPort card enough to grasp it by the edges.
Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac Mini.
2014製 Mac mini に接続されたモニターの画面がちらつき始めたので、いろいろと確認しました。
High Speed 4K HDMI ケーブル が怪しいので確認しました。
Mac 側のHDMI ケーブルコネクタを動かしたところ、モニターの画面がちらつき始めた
Apple のサポートに見積もりを取った。5万円の見積もりが来ました。
16 farklı kişi bu kılavuzu tamamladı.
4 Yorum
is there any internal battery on the logic board..
It is called a hard drive tray or hard drive carrier. You can find the guide to remove it here.
