Ana içeriğe geç
Mac mini Late 2014 Logic Board Replacement
Neye ihtiyacın var
  1. Mac mini Late 2014 Logic Board Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
    Read Me First: I purchased an SSD drive directly from Crucial and, of course, it came uninitialized. After going thru the entire tear down, installing the new drive, and rebuilding the mini, it refused to recognize the new drive. So, of course, I had to re-tear it down, remove the new drive, insert it into an external housing and format it using my Macbook. After that the mini recognized the new drive. A word to the wise: format the new drive before installing it.
    tom - Yanıt
    How were you installing the OS? I am planning on booting into a USB drive with a copy of OS High Sierra on it, and I assume I will be able to format my new Samsung SSD using that?
    Simon - Yanıt
    On my Samsung EVO 850, mac mini download system automaticly
    Stefan Repac - Yanıt
    Pre-formatting is not necessary if you make a USB boot installation drive with macOS installer. During boot up, hold down the option key until the mac boot into the USB, formatting can then be done using disk utility running off the USB drive.
    SBR249 - Yanıt
    I had the exact same experience as tom. I installed a brand new 2TB Samsung 850 EVO and it was not recognized by the Mac Mini. I booted from a portable USB drive with a bootable copy of macOS High Sierra but the 850 EVO SSD I had just installed was not shown as an option. I tore down the Mac Mini again, formatted the 850 EVO, rebuilt the Mac Mini, and booted off the same bootable High Sierra USB drive, and sure enough the 850 EVO was recognized.
    maxim - Yanıt
    diskutil list
    diskutil erasedisk [filesystem] [drivename] /dev/disk[disk number]
    Paul Rodgers - Yanıt
    My drive (Evo 860) was also not initialized. I started in recovery mode and went to disc utility and from there selected the drive. I then was able to use the “erase” function on the drive. I just left the settings as default and as soon as it erased then the drive was ready to go.
    Nathan Cooper - Yanıt
    Just completed this upgrade a few days ago, having purchased the 1 TB SSD kit from IFixIt. The kit arrived quickly and the tools and drive worked perfectly. The step by step guide posted here is pretty much flawless, but do pay attention to the specific comments from users on certain steps - they really help. As far as ensuring that the new drive will reboot and install MacOS, I watched 1-2 videos on YouTube about re-installing using the Internet Recovery tool and that worked perfectly. My MacMini is performing WAY better than it used to, for only a $200 upgrade kit and about 3 hours of work, all in. Thanks!
    Joshua Rednik - Yanıt
    I’ve had Apple computers since the G3 machines and they have always been snappy.
    Unfortunately this 2014 macmini has always been slow but this upgrade (6 years later) has changed that!
    if you have a late 2014 macmini, do this.
    I used a 860 Samsung.
    Mike Hayes - Yanıt
    A quick comment to tell you that at every step, make sure to read the comments and be careful. I managed to do the process fast without any problems, but thanks to the comments that warned me enough on the risky steps.
    Euronymous - Yanıt
    This guide surely helped me breath upgrade and bring some new life into my macmini. Thanks to all who contributed.
    Cameron Hasell - Yanıt
    can one of you give me the link for the screw drivers please?
    Gerardo Ramirez - Yanıt
  2. Mac mini Late 2014 Logic Board Replacement: adım 2, 3 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 2, 3 resimden 2. Mac mini Late 2014 Logic Board Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
    I used some wooden toothpicks instead of the opening tool. This worked flawless for me.
    mhomscheidt - Yanıt
    Credit cards will also work. The cover should should pop off easily.
    Gregory - Yanıt
  3. Mac mini Late 2014 Logic Board Replacement: adım 3, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 3, 2 resimden 2.
    • Lift and remove the bottom cover.
    I taped the "Mac Mini Logic Board Removal Tool" to the flat part of the antenna plate before sealing everything up again. I mean, where else am I supposed to store it without forgetting where it is? I'm pretty sure it won't cause any problems there.
    Richard - Yanıt
    That’s a brilliant idea, @mrredwood!
    Dan Moore -
    Lol. And here I am keeping this old system going a little longer with a 2TB upgrade.
    Richard -
    I would suggest you wash the underside of the plastic as mine after 3 years was covered in dust.
    John Errington - Yanıt
    I couldn’t get mine to snap back on
    David Yutzy - Yanıt
    Make sure the 3 longer, thicker screws are in the right holes per the diagram in Step 4. (Hint: not next to the large black wireless button.) When those screws are in the right places, the back just snaps into place very easily.
    Gary W Edson -
  4. Mac mini Late 2014 Logic Board Replacement, Antenna Plate: adım 4, 1 resimden 1.
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
    Had a T7 security screw driver [and didn't want to wait to have the T6 version shipped to me], so I gave it a whirl. I lined up the driver with the screw socket, pressed down a bit to make sure the driver would get enough grip, and slowly [but forcefully] rotated the driver and got these screws out. BE CAUTIOUS not to strip the screws. May not work for everyone.
    KevCoStudios - Yanıt
    As TR6 screwdrivers were sold out all over Germany and I wanted to exchange the HDD THIS friday, I took a VERY fine dental milling tip (0,8 mm head diameter) for my proxxon and milled away the little dots in the center of the the TR6 screws. After that I could open the case with a regular T6 screwdriver. All went fine, MM is closed again + working like a charm with it's new SSD. NOTE: For this task I used my loupe glasses (3x) ;)
    Martin Gerner - Yanıt
    On the whole screw thing. I just used a tiny dremel drill bit and drilled out the security pin. I hate those screws. I don't see the point in locking the them with those. they should have left the screws alone.
    That Mac Guy - Yanıt
    That worked for me, thanks for the trick!
    Arroba -
    great trick!
    James Almeida -
    I used the T7 very carefully. No problems.
    randywardak - Yanıt
    I just had success using standard pliers to remove the longer screw posts, and then I used standard needle nose pliers to press down and grip the tiny screws. Please note that this method may/will cause scrapping of the aluminium cover.
    Barrythetech - Yanıt
    Northern Tools sells a set of 13 Torx Security Keys for $28.99 that has the TR6 size.
    Gary Craig - Yanıt
    On my 2nd drive replacement (swapping out to an SSD this time). Could not find my logic board removal tool. So I made another one from a metal coat hanger. So, here’s my tip, when you put it all back together: the logic board removal tool fits around that small black circle antenna perfectly and you can replace the large black cover over the top snuggly. No rattles or anything.. So, next time: I’m guaranteed to find my logic board removal tool.
    Andy Milne - Yanıt
    The three longer screws could be removed with pliers.
    The three shorter once I drilled out with a sharp 3 mm drill.
    First put tape across the ventilation opening and carefully vacuum cleaned before taking of the antenna plate, though.
    Don’t you hate it when the manufacturer does things like this, though??
    ernstcline - Yanıt
    My set of drill bits contained a T6H but no TR6 (I don’t know the difference). That worked too without problems
    Claus - Yanıt
    I can recommend the Tekprem tools for this. That %#*@ security dimple foiled me until I got these. check Amazon ratings before you buy any tools, a lot of them that come from China are made with cheap pot metal rather than properly hardened alloys and will strip out very quickly. (Don’t ask me how I know this.)
    MrSpiral - Yanıt
    I have T6 but not the required TR6, and my order for the bit from Amazon is going to take two weeks. I don’t have the patience to wait so…
    I was able to remove all of the screws but 1 with a pair of needle nose pliers and sheer force of will. The last one wouldn’t come off so I just finally gave up and bent the plate back until the screw broke off. It wasn’t pretty but considering there is a plastic cover over the whole assembly it was something I was willing to live with.
    Note that I can’t get the screws back in with the needlenose, they just don’t turn, so I will await the bit to arrive. In the meantime this computer is purring like a kitten, a whole new lease on life!
    Glen Candlewood - Yanıt
    If you have non-security T6 and T7s, carefully drill away the middle of the screw with a very small bit, stopping frequently to vacuum out the filings to see if you’ve done enough. You don’t need to do much, and too much will strip the screw entirely. Then very carefully unscrew using a T6 (you may need a T7). I’ve done it twice and it works.
    bkbkbk - Yanıt
    Crap, i'm stuck on these, too, and it's just the very beginning.. What can I say, that's simply unfair not to say plain stupid, Apple, but it's nothing new.
    Alexey Lyskov - Yanıt
    I can confirm that the small pin in the middle of the TR6 screws can be removed (actually broken out) pretty easily with a small, flat head screwdriver that can just fit inside the middle hole of the screw (as recommended in some YouTube video).
    First, cover the antenna plate holes for safety. Then push the dots with the  flat head screwdriver from one side cautiously, but forcefully by leaning the driver against the outer side of the inner hole, until you see the security pin leaning a little bit. Then push it from the opposite side, until it breaks out.
    Bacs - Yanıt
    I've been fixing and upgrading Apple products using iFixit since the days of Gen2 iPod Touch and white plastic iBooks. This is the first time I had to use a drill press!!! To grind out those darn internal pins. But it worked. Now awaiting delivery of an SSD with my Mac mini in pieces on my desk. Thanks, iFixit and all the comment posters.
    buyer14618 - Yanıt
  5. Mac mini Late 2014 Logic Board Replacement: adım 5, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 5, 2 resimden 2.
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 Logic Board Replacement: adım 6, 1 resimden 1.
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
    This is a pain in the arse to get back on. Lock the screw down first when reassembling.
    Jim Allen - Yanıt
    No need toremove this. The cable squeezes out of the gap under the case with enough length for the antenna plate to be out of the way.
    cheongi - Yanıt
    Not necessary to remove just be careful and don’t stretch the cable.
    peter Tucker - Yanıt
    Steps 6 - 9 are not needed…
    Gray Greensheim - Yanıt
    I found it necessary to remove the screw (as instructed) as my antenna cable was attached to the washer.
    Ivan - Yanıt
  7. Mac mini Late 2014 Logic Board Replacement: adım 7, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 7, 2 resimden 2.
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
    Is this really necessary? The antenna is no where near the SSD drive....
    mike - Yanıt
    This was the most tricky part for me when remounting the Mac Mini. With my bad eyes, I’ve spent 10 minutes inserting this tiny round antenna plug in the hole. I’ve decided to put the screw back without tighten it too strongly and then it was easier.
    afajner - Yanıt
    I have been having wifi issues ever since I changed the drive. I don’t know if this connector is the cause or not.
    Simon - Yanıt
    I have been having wifi issues ever since I did this upgrade. Don’t know if it’s this connector or not.
    Simon - Yanıt
    Afajner great rip. Worked great. Thx
    Milton - Yanıt
    Afajner, your tip worked great. Thanks.
    Milton - Yanıt
    This is a very fiddly connector. Afajner’s tip is recommended. Make sure the connector is in securely. It will not wiggle or make a ticking sound when pressed when it is seated correctly.
    maxim - Yanıt
    I had trouble at this point too. My experience: Loosen the screw a bit and than center the antenna plug over the pin. In my case I heard a click when I plugged it in correctly. Don’t forget to tighten the screw afterwards.
    Matthias - Yanıt
    mike - 06/25/2017
    UP! is it?
    sandro.vezzali - Yanıt
    Not strictly necessary for SSD access, no—just allows you to detach the antenna plate and get it safely out of the way. You can leave it in place if you prefer, but be careful to support the antenna plate and make sure the cable doesn’t get strained or yanked accidentally.
    Jeff Suovanen -
    Wenn nur die M.2 gewechselt werden soll, empfehle ich, den Antennenstecker nicht abzuschrauben und den Deckel einfach vorsichtig beiseite zu legen. Es ist dann allemal genug Platz zum Wechsel der M.2.
    Das Ausstecken dieses Steckers ist hier wirklich nicht einfach, da die Anschlüsse winzig und mit bloßem Auge kaum zu erkennen sind. Hat bei mir gut 20 Minuten gedauert, bis ich das Teil wieder drauf hatte. Eine Lupe kann hier wirklich helfen. Auch das vorherige Fixieren mit der Schraube macht es ggfs. etwas einfacher. Der restliche Ausbau/Umbau/Zusamenbau war nach einer knappen halben Stunde erledigt und ist für jeden mit etwas Geduld machbar.
    Des weiteren aufpassen mit der winzigen Schraube, die beim Zusammenbau leicht verkanten kann und dann sehr schnell abreißt.
    Hermann Röttger - Yanıt
    In trying to remove the antenna connector pin from its socket on the airport card the socket came away from its location on the airport card completely, together with the cable and connector pin. Rather than replace the airport card (that would have a new socket) and a new connector/pin for the cable, I decided it would be worth trying to solder the connecting pin to the (now exposed) contact points for the socket on the airport card.
    Best time to do this is during the re-build _after_ replacing the hard drive, when the antenna is still unattached to the airport card. After the re-build (with no further problems encountered) it was quite easy to solder the connector pin with attached remains of the socket to the airport card's contact points - there's enough space for easy solder access without other sensitive components nearby.
    I had thought that my Mac Mini's wireless connectivity might be affected, but it wasn't.
    Now very happy with a fast SSD machine with wireless connectivity.
    David Paul - Yanıt
    this was the most fiddly part of the reassembly operation for me too. Old eyes, despite good lighting, led me to try this multiple times before I finally got that satisfying click. I am surprised that people find securing the screw first to be helpful, as I didn’t have nearly enough room to move the cable around if I tried that. Also, while it is theoretically possible to do this entire operation without removing the cable, I would never chance it… It’s way too easy to damage something by yanking on the plate. I had a lot of peace of mind when I was able to set the entire antenna plate aside.
    MrSpiral - Yanıt
    After I reassembling, my bluetooth no longer works. The antenna connector is definitely seated properly as I heard the click, and it was fully secured when I tried to wiggle the wire. Did anyone else have this problem?
    Sean Dickson - Yanıt
    Update: when I disconnected the antenna cable, OSX retained my keyboard and mouse in the bluetooth device list, but it had apparently forgotten they were paired. I bought a usb keyboard and usb mouse to figure this out. Deleted the devices from the bluetooth list, rediscovered them, and now it’s working fine.
    Sean Dickson -
    Getting this connector back on was the single most annoying part of the process. I agree with loosely reattaching the screw first to hold the cable in place. I then used tweezers to manoeuvre the head of the cable into position and my finger to push it down.
    gdubai - Yanıt
    To everyone making comments regarding their experience - fabulous!
    Donn Tarris - Yanıt
  8. Mac mini Late 2014 Logic Board Replacement: adım 8, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 8, 2 resimden 2.
    • Carefully pull the antenna cable out from the gap between the power supply and case.
    Use tab that the screw goes through to align the connecter more easily.
    Rob Speight - Yanıt
  9. Mac mini Late 2014 Logic Board Replacement: adım 9, 1 resimden 1.
    • Remove the antenna plate from the Mac mini.
    To save time and effort, note that you don’t need to disconnect the antenna cable from the radio module. Just carefully lay the antenna plate / cable assembly over to the side and perform the SSD switch.
    clinton - Yanıt
  10. Mac mini Late 2014 Logic Board Replacement, Fan Assembly: adım 10, 1 resimden 1.
    • Remove the two 12 mm T6 screws from the fan.
    • Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
    That 27mm screw should be very loose, since it attaches the motherboard to the case. When you’re trying to remove the motherboard, if the AC connection side of the board is not moving back easily, you need to make sure this screw is fully backed out from the case.
    There’s no danger in removing it completely.
    marklfarley - Yanıt
    I suggest removing the 27 mm tool, otherwise Step 23 will not work.
    Arvin Bhatnagar - Yanıt
    Actually you don’t need to remove 27mm from the fan. I was able to tilt a little when I take the logic board out in Step 23. I also didn’t take the fan cable too. When you pull the logic board out, put the fan on the back of logic board as you pull it out.
    Kenneth Z - Yanıt
  11. Mac mini Late 2014 Logic Board Replacement: adım 11, 3 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 11, 3 resimden 2. Mac mini Late 2014 Logic Board Replacement: adım 11, 3 resimden 3.
    • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
    • Do not attempt to remove the fan entirely.
    • Lift the fan straight up to free the captive screw from its hole in the logic board.
    • Pull the fan away from the SSD until you can easily access the fan connector.
  12. Mac mini Late 2014 Logic Board Replacement: adım 12, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 12, 2 resimden 2.
    • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
    When I did this the entire socket came off the logic board. What do I do now?
    Tyler - Yanıt
    I broke off the connector. More photos of the connector may help. I lifted it but the pins broke off. It took me awhile to find points on the board to solder the wires to. I got 3 of 4 wires and the fan operates.
    Beryl Sachs - Yanıt
    I would suggest NOT using the point end of the Spudger but the wide end. Place behind connector (wire side) and twist gently.
    If I may be so bold as to also suggest that a torch be used for those small components/connections.
    TisMise - Yanıt
    Thank you, @TisMise! I placed the wide end of the spudger on the wire end of the connector and wiggled it up. The connector comes lose up - NOT out front in direction of the wires. Hope this helps. ?
    CK3 -
    "If I may be so bold as to also suggest that a torch be used for those small components/connections."
    Seems like overkill and likely to melt something. -some american
    maccentric -
    I also broke the socket off. I don’t have the ability to solder little $@$* like that. I’m sad.
    Daniel Rackerby - Yanıt
    broke it… how bad is the no fan option?
    Kris Chu - Yanıt
    @TisMise you’re right thanks a lot! ;)
    Stefania Izzo - Yanıt
    You don’t need to disconnect the fan cable to take out the logic board. When you slip the logic board out, put the the fan behind the logic board as you push it out.
    Kenneth Z - Yanıt
    Definitely use wide end.
    Peter Harrison - Yanıt
    That’s it, I used a needle! After reading so much people broke it, I rejected this step instruction and put a needle between the socket and the connector. It came out fine. Good that I also fix clothes, other than computers. :)
    Seff - Yanıt
    As Kenneth Z said, I just left the fan attached to the board for the entire process (I removed the screws so it was just connected with the cable). After reading all the comments, I was too afraid to try to force it and it did not come off easily. Keeping the connector on is a little dangerous because you have to be careful not to pull on that connector too much but it seems pretty robust, which is probably why it is so difficult to removed. I just slipped the fan through after I pulled out the main board assembly.
    Richard Daley - Yanıt
  13. Mac mini Late 2014 Logic Board Replacement: adım 13, 1 resimden 1.
    • Remove the fan from the Mac mini.
  14. Mac mini Late 2014 Logic Board Replacement, Logic Board Assembly: adım 14, 1 resimden 1.
    • Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
    This screw is very short, when I tried to put it back, the beginning of its thread got dusted and now it's impossible to use it to fix the bracket in place. It should be 3.5 mm instead of 2.6. Nevertheless, the SATA connector is firmly attached to the logical board withou screw+bracket and my mac mini is working nicely.
    mario.estolano - Yanıt
    My mini came with only a PCIe SSD on it. When I got to this point, I discovered that because it was never shipped with a hard drive, there was no securing screw, no cable connector bracket, no cable connector, and no hardware for securing the drive. Fortunately, there is still a hole in the logic board where the SATA cable is supposed to pass through, and the logic board does have the appropriate connector. if you buy an OEM SATA cable, you can actually secure the SSD in place using a little bit of electricians tape. Because it has no moving parts, it’s not going to rattle itself loose. I am more concerned about not having a cover for the place where the SATA cable clips to the logic board, but I put a little electricians tape over it to hold it in place and I will see how that works.
    MrSpiral - Yanıt
    If you are adding a sata drive to a pcie mac mini 2014 only you wont have this part - as per MrSpiral’s pos. Using a 2012 additional drive kit will give you the sata connector to connect the drive to the logic board but not the securing screw and plate (next step) it would be good to be able to get this part. if anyone has any links that would be appreciated.
    Edward Chandler - Yanıt
  15. Mac mini Late 2014 Logic Board Replacement: adım 15, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 15, 2 resimden 2.
    • Remove the SATA cable connector bracket.
    This procedure works to add a SATA hard drive/SSD to a PCIe SSD-only Mac Mini using iFixit's Mac Mini Dual Drive Kit. The one thing that's missing from the kit is SATA cable connector bracket (and screw). This is not the end of the world: the cable is a snug fit in the logic board socket, so the bracket is only a safety measure.
    Dominic Dunlop - Yanıt
    Its shown in the 2nd picture but is very easy to skip over and I almost lost mine because I did exactly that. While I thing the connector would stay without it The little cover that hold the connector down would be a bad thing to have floating around in the machine.
    jeh.dominic - Yanıt
  16. Mac mini Late 2014 Logic Board Replacement: adım 16, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 16, 2 resimden 2.
    • Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
    Last time I did this I got the tool under the socket and it broke off. This caused the power light not to work. I don’t use the IR function so it wasn’t an issue. When putting this connector back on, make sure it seats well as many have has issues with the the power light not working. You will read more of this on the comments at the bottom
    Greg Bouten - Yanıt
  17. Mac mini Late 2014 Logic Board Replacement: adım 17, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 17, 2 resimden 2.
    • Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
    Be careful in this step. I am known for my gentle hands and the little cable flew out regardless. Was able to reinsert with no damage but was terrifying!
    Liliana Chavez - Yanıt
    What if the entire connector came off? Can this be glued again? How can I fix this?? :(
    Cai - Yanıt
    @caicruzz The socket will have to be re-soldered to the board. It’s not terribly difficult, but requires some specialized equipment and I wouldn’t recommend it as a DIY on any machine you care about, at least not without a lot of practice first. I’d suggest reaching out to a repair shop that handles board-level repairs. Sorry for the frustration! Accidents happen sometimes; fortunately this one is very fixable.
    Jeff Suovanen -
    This happened to me as well. Can I simply tape it in place? I’m never going to use the IR sensor anyway.
    Joseph Stillwell - Yanıt
    Is you made mini working without connecting the Broken IR bracket? I did this the other day and I can live without the IR and LED light. I could solder it, but rather not if the machine works without it
    John Kokkas -
    I did this. So mad at myself. Will my Mini still work if I left it as is. I understand that I won’t have IR and the LED light won’t work, but I can live without it
    John Kokkas - Yanıt
    I broke it too. Really annoying as I do use (or, used to) the IR sensor).
    Of course I broke mine off… Be careful when you put the cable in! The Mini is working without it but no IR and LED on the front.
    bigsee - Yanıt
    Use a fine tip set of tweesers and slip the end under th wires and gently pry up.
    juggledad - Yanıt
    Je l’ai cassé aussi ….
    Bruno Villers - Yanıt
    I would recommend to go on till step 24, till the motherboard is pulled out slightly, then come back to this step. The space is very tight between the connector and the hard disk bracket, which makes it difficult to slide the spudger underneath the wires. It is much easier when the motherboard is slightly out and have more space for the tool. I followed @juggledad’s comment, and used a pair of fine tip tweezers to pry the connector out.
    Xu YANG - Yanıt
    Capteur cassé; comme vous autres
    Pierre-alexandre98880 - Yanıt
    You may also use a bowed paper clip and slide it under all wires and gently pry it open
    Gero Alexius - Yanıt
    Because of the warnings in the comments I decided to use another tool. Instead of using a spudger, I carefully used the Flathead 1 bit from the iFixit Mako precision bit set in this step. That worked well for me.
    Sicco Pier van Gosliga - Yanıt
    YES! I followed recommendation to go on till step 24, as Xu Yang suggested. Worked easy for me. Thank you all!!!
    Efrain De Luna - Yanıt
    Thanks for the recommendation to wait to remove this one, often find the comments on these guides so useful.
    Ahmad - Yanıt
    Seff - Yanıt
    IR connector also controls Bluetooth.
    Jon Dear - Yanıt
    I moved the mainboard too far away and the cables came out of the connector, without damage (whew). In this situation, when putting back the pins in the connector, remember that the pinout is plain simple: referring to the other end of the cable the order is pin-to-pin (1 to 1, 2 to 2, etc.).
    Walter Ferlazzo - Yanıt
  18. Mac mini Late 2014 Logic Board Replacement: adım 18, 1 resimden 1.
    • The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
    Steps 18-20 only apply if you are removing a fusion drive. Otherwise skip to step 21 during removal.
    Stephen Reaser - Yanıt
  19. Mac mini Late 2014 Logic Board Replacement: adım 19, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 19, 2 resimden 2.
    • Remove the PCIe SSD cable bracket.
  20. Mac mini Late 2014 Logic Board Replacement: adım 20, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 20, 2 resimden 2.
    • Lift the PCIe SSD connector up off its socket.
    Is the PCIe connector present and usable on the mid-range Mac mini? I don't need the ~$300 fusion drive but would like the comfort of knowing that I can add an extra SSD in the future.
    Michael Johnson - Yanıt
    No, only present in Mac Minis configured with a fusion drive.
    rasmus - Yanıt
    Not true. I am looking @ the inside of a mac mini _not_ configured with a fusion drive, and the connector is present.
    Samuel Bostick - Yanıt
    The PCIe connector is only present if the computer came factory configured with any sort of flash storage (SSD or fusion drive). Otherwise, the cable, the connector, the bracket, and the 2 screws are all missing. The fusion drive is essentially a disk drive plus a small capacity SSD blade which the OS recognizes as a combined drive. Fortunately, if you didn’t have an SSD before, you can easily buy the connector cable part on the internet. The bracket and screws are not necessary.
    SBR249 - Yanıt
    Is it correct that the “iFixit Mac mini Unibody SSD Upgrade Bundle” with a 500-Gbyte Crucial MX500 SSD does not require a PCIe connector? This is for a late 2014 Mac Mini with a failed HDD (order number MGEM2*/A). I think it is correct, as the connectors on the Crucial SSD look just like those on the HDD, but just checking…
    David Newman - Yanıt
  21. Mac mini Late 2014 Logic Board Replacement: adım 21, 1 resimden 1.
    • Remove the single 16 mm T6 screw securing the logic board.
    There were 2 screws on the Mini I disassembled.
    Keith S Coker - Yanıt
  22. Mac mini Late 2014 Logic Board Replacement: adım 22, 1 resimden 1.
    Bu adımda kullanılan alet:
    Mac mini Logic Board Removal Tool
    Satın Al
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
    Instead of the removal tool it is also possible to use two metal pins with 2,5mm diameter.
    Yuuki Galaxy - Yanıt
    A T8 screw driver worked best for me on the 4 hard drive screws.
    rparks89 - Yanıt
    Yes - You need a T8 there rather than T9.
    amrgardner -
    T9 was a perfect fit for me.
    dloftis -
    T8 screws in my HDD
    aiino - Yanıt
    You don’t need a tool for this step, just turn the Mac Mini around 180º and push the vent for the fan with your thumbs. The board will push straight out. That’s what I did.
    Daniel De Ciantis - Yanıt
    Sure, nice tip - it works for me fine - thks for it :D
    Tom
    Tomáš Pokorný -
    Nice tip, thx
    Mats -
    Simple thumb-pushing didn’t work for me, so I bought the tool.
    Insert the MMLBRtool. How far? There’s an initial lip you might catch about halfway down, but wiggle beyond the lip to a definite bottoming out, and equal lengths of the tool on each side of the elbows as shown.
    As you lever the logic board per the illustrations, you’ll notice the black bezel begin to separate on one side or the other. Use a prying tool or guitar pick to help separate the bezel from the body on top and bottom, and the logic board will slide out easily with gentle prying.
    On my Mini, the bezel’s retaining clips (best seen in Step 25) were very snug to the body, preventing the thumb-push. Using the pick released them from the body.
    s gardner - Yanıt
    You definitely don’t need the tool. Just get two screwdrivers small enough to fit in the holes and push them both at the same time. I have about a million tiny torx screwdirvers that came with iphone screen replacement kits. I’m sure you do too.
    Mark2000 - Yanıt
    This is exactly what I used, thanks for the tip. Worked a charm once I leveraged both small screwdrivers back with even pressure just like you can with the removal tool.
    Ahmad -
    I used an old coat hanger. I just cut the end off with some pliers and then bent it into a similar shape as the tool. The biggest thing is making sure both sides are about the same length. Also, don’t put your thumbs on the black plastic part on the back of the mini because you won’t be able to pull the logic board out that way.
    As I didn't have the Mac mini Logic Board removal tool, I used two small Alien tools, similar to the Mac mini Logic Board removal tool.
    marcoscaj - Yanıt
    I paid the five bucks and I am really not sorry I did. Yes, I probably could’ve made my own or fiddled it out with a couple of screwdrivers, but without having done it before, knowing how much leverage to apply and in which direction was made much easier by using a proper tool.
    MrSpiral - Yanıt
    I used 2 screw drivers as suggested, and pulled towards me with my palms against the sides of the case. Even with a lot of muscle, I failed. The solution was to get a helper on the opposite side of the table. Using the fingers of both hands along the circular opening in the case, the helper pulled as I pulled on the screwdrivers. They should be kept vertical, so as to not damage the board. There is no way the procedure pictured in step 23 would have worked for me. My board must have needed at least 20 pounds of force to move
    mail - Yanıt
    Totally didn’t need to buy the tool they recommended. Just use two tiny screwdrivers (the same ones you are already using to take apart your mac. Pull at the same time toward you and the whole board popped out in a few seconds.
    Scott Provost - Yanıt
    etape la plus délicate du tuto, j’ai pour ma part fait levier avec la partie plate de la spatule en plastique entre le berceau du disque dur et la carte mère juste à coté du connecteur ir, la facade s’est légerement décollée, j’ai changé de place toujours avec la même méthode et la facade a continué de sortir, j’ai ensuite pu aider avec les trous initialement prévus (j’ai utilisé 2 tournevis torx très fin) et ensuite c’est sorti sans souci
    Olivier VH - Yanıt
    I had the tool and it worked perfectly. However, it did not push easily out. It came out hard and nearly went flying. Luckily nothing was damaged but just FYI, mine was super tight.
    LESLIE DOW - Yanıt
    You totally don’t need the one-use-only “logic board removal tool”, that’s silly. If you push against the heatsink with both thumbs (being careful not to make the board flex) and wiggle it out it’ll eventually give and slide out.
    Gary Diamond - Yanıt
  23. Mac mini Late 2014 Logic Board Replacement: adım 23, 3 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 23, 3 resimden 2. Mac mini Late 2014 Logic Board Replacement: adım 23, 3 resimden 3.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the removal tool makes contact with the opening in the rear case.
    • Remove the Mac mini Logic Board Removal tool.
    I had some trouble getting mine started here. If your logic board seems stuck, try pushing the removal tool on both sides near the bottom (vs the top like the photos show) with your index fingers, holding the case with your ring and pinky fingers so that your hands are completely free of the back of the computer (the side with the ports). This worked for me. Otherwise, this guide made the process smooth!
    Jeff - Yanıt
    I had the same issue until I read this comment. Worked as explained. Thanks !!
    marcstonge060698 -
    The removal tool fits into sockets below the board, just 'lean' the tool over and the logic board will ease out. When refitting the logic board make sure the tabs around the I/O shield slip inside the shell and press home firmly. If the fixing screw does not thread into it's hole, the board is not fully home.
    Malcolm Norwood - Yanıt
    This is what worked for me!
    Rick Allen -
    Make sure you do *not* have your thumbs on the black plastic I/O shield while attempting this step!
    I was able to push the logic board out, with a little bit of stress and patience, without the specified tool. Rather I used two paper clips, larger than average, and being very gentle to get the initial nudge. I then finished it off using only my fingers, as the paper clips were not strong enough and would have bended. Doable, but probably easier with the tool.
    mt - Yanıt
    Even with the tool - it takes more force than you think. There are clips on both sides of the board. Be aware of that when putting it back.
    Jim Allen -
    I used 2 mini flathead screwdrivers with the same thickness as the holes with the heads aligned straight up and down. They will fit into little sockets attached to the case below the board. The side with the power cord came out much easier than the side with the headphone jack, so I removed the tools after a small gap was created and pushed semi-hard on the logic board with a broken spudger (a screwdriver would have worked, too) right in the elbow curve shown to the left of the screw in step 14, and the whole thing slid right out.
    unixmonkey1 - Yanıt
    I saw a video where a guy just used a coat hanger to make his own tool. Good to know in case you've already started taking it apart and haven't already purchased the tool. https://www.youtube.com/watch?v=hgEBPlz4...
    James Almeida - Yanıt
    The coat hanger trick worked flawlessly for me. Very easy.
    Jochen -
    May be its me, but I had a right issue with this, I then noticed the screw I loosened in step 10 was bending over. I removed the screw completely, logic board came out, and the metal pillar on the underneath of the board where said screw went in was bent. When I put it all back together afterwards after changing the drive, that long screw was bend, on straightening everything up, the pillar snapped off the logic board. Everything tightened up and its booted up fine. It might just me not following the instructions properly though
    steve - Yanıt
    Same here. The screw has to be backed out further than I thought. This should maybe be clearer.
    marklfarley -
    For me the screw loosened in step 10 came out with the fan. it "should" be a captive screw meaning it doesn't stay in when the fan comes out
    Bill Pennock - Yanıt
    I had 2 complete sets of allen wrenches, one metric and one standard and found one each that fit the holes perfectly. With those I was able to find the "pry spots" that are on the base of the case very easily and a slight nudge moved the board. really worked EXCELLENTLY
    My logic board was hung up on the left side with the plastic retainer or the two grounding tabs not giving up the ghost. There is no good picture of this on this procedure. If you go the the heat sink replacement procedure you can see a pretty good bit of it below the presenter’s right thumb in the opening pic and in a larger pic at step 27. Not that the logic board assembly can move much while seated I was able to shift (ever so slightly) the black plastic backside to the right and the board finally unlatched and came out. I was so worried that I was going to over force it and break something, you know, like the logic board. Not sure if I have a solution other than don’t force it. If it seems hard and one side seems to have a screw or other some such locking device stop forcing it and try shifting the logic board to the side opposite were it is catching.
    Eric Jorgensen - Yanıt
    I had an issue during reassembly where the AC in socket was just offset and would not line up correctly. I inserted the power cord (unplugged from wall) as I did the final push and everything finally lined up right.
    Austin McGuire - Yanıt
    One thing about sliding the assembly board in, i.e. when you are doing the steps backwards, is that there is squishy pad on left and clip on the righ (when viewing mac mini from bottom) if you carefully observe and then it becomes easy to get the assembly in or out if you think about it.
    Trushar - Yanıt
    Though I’m sure the tool would work really well, we were able to trouble shoot this with an old microwave oven tray. We clipped the pieces and they were strong and small enough to help remove the logic tray.
    Kuldip Kainth - Yanıt
    This step seems like it would be easier with a lot of thin tools like iFixit’s Jimmy being used to release the clips holding the IO panel to the case. It will slide apart with brute force, but until you realize what’s holding it shut, it feels like more force than it reasonable.
    Patrick Friedel - Yanıt
    marcoscaj - Yanıt
    No clips or screwdrivers. I used my barehands over the air tunnels, that was very quick.
    I’m not sure how safe it is but worked just fine for me.
    Antonio Cuamatzi - Yanıt
    This was very daunting going in (I had flashbacks of iPhone 4 screen replacements), but turned out to be mostly a breeze. Despite the amount of steps everything inside is very modular and fastened with a minimum number of screws. Logic board module slid right out with very slight pressure on the air vents. Most difficult part was getting the DC connector out and the side clips of the logic board module back in. Much to my surprise, I had it all done in 25 mins. Excellent guide.
    Mitch Russell - Yanıt
    I used a single mini/ Jewelers philips screw driver #0 that fit perfectly into the hole and he socket at the base. A gentle “lean in” on each hole loosened the board, ready to slide out.
    Torsten Borchers - Yanıt
    After some head scratching I found you don't want to insert the removal tool too deep. If you do you wont be able to slide the board out.
    Sam Pearson - Yanıt
    YES. What is not clear on the pictures is that the whole board slips as a drawer, as shown on picture of step 25. When I understood this, it helped a lot.
    JICRO - Yanıt
    I followed the advice of a pro, put the machine on the floor and my knees to the back end corners. From there I could push with screwdrivers down the holes and it loosened.
    Esben Harbo - Yanıt
  24. Mac mini Late 2014 Logic Board Replacement: adım 24, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 24, 2 resimden 2.
    • Pull the DC-In cable connector straight out of its socket on the logic board.
    When reassembling, I made the mistake of pushing the logic board all the way in before trying to reattach the DC-In cable connector. It is much easier to reattach the connector with the logic board pushed in just short of final seating.
    Saqib Qazi - Yanıt
    Very usefull comment!!!
    Jean-Marie Sengelen -
    Excellent tip, thank you! I would suggest to @sam that this tip be added to the main steps so that others are more likely to see it. Saved me a lot of potential difficulty!
    Ian Davies -
    very small needle-nose pliers help, when reassembling.
    allanschwartz - Yanıt
    This is very tricky and to get it off requires a fair bit of (considered) force. Putting it back on I also found a little difficult until I realized it seats slightly lower than you might anticipate. The connector isn’t flush with the top of the motherboard.
    Rob Speight - Yanıt
    I was going to make this comment too. I spent 10 minutes trying to plug it in. It sits much lower than I expected too.
    Richard Daley -
    I agree with the comment above. When you’re putting everything back together, take time to see the connector properly before you push the logic board all the way in. It saves a lot of hassle.
    MrSpiral - Yanıt
    I could not get my big fingers in to grip the wires. I used a small flat bladed screwdriver against the tiny ridge on the top of the connector. I pried against the board.
    mail - Yanıt
    Use some tweezers to help work out each side as you pull with your fingers.
    I pushed down on all the wires against the black plastic frame beneath to secure the wires tight. This allows you to then pull the logic board from the front until the connector pops out.
    Julian Robbins - Yanıt
    Pour faciliter l’extraction de cette nappe de fil j’ai fait une boucle autour de celle-ci avec un lien fait d’une fine bande de plastique noir muni en son centre d’un petit fil de cuivre pour la solidité, on trouve ce genre de liens au moment du déballage de matériel électronique ou ils servent à tenir les câbles enroulés dans de petit sacs plastique. Une fois enroulé autour de la nappe il suffit de tirer sur cette attache ce qui permet de tirer sur tout les fils de la nappe en même temps et ainsi d’éviter de tirer uniquement sur quelques fils.
    Patrick Ponsard - Yanıt
    Thanks for a thorough guide, except for one point -
    the Hard Drive connector landing point on the Logic Board. I did not notice how the connector came off when I pulled the Logic Board.
    Please add a circle around that connector on the logic board, AND how to get it re-installed. I ended up ripping the tiny gold "connections" off of a logic board when trying to get the Hard Drive cable re-seated.
    Edward Westerdahl - Yanıt
    I actually missed the step prior and had to remove after I called loosened the mother board. Fortunately, when I pill on the board to come out, it conveniently pulls out this connector at the right angle.
    Joe - Yanıt
  25. Mac mini Late 2014 Logic Board Replacement: adım 25, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 25, 2 resimden 2.
    • Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
    When sliding the logic board assembly back in later, mind the tabs, especially those at each end.
    Richard - Yanıt
    When sliding the logic board back in, also be careful and make sure the rubber “sock” on the logic board wraps around the AC-in socket on the power supply.
    Anton - Yanıt
    If you can’t get the logic board assembly back in so that it is flush (as it was before you did your surgery on the machine) then I would pay attention to two things: 1) the “sock.” Make sure it is back in place in the right way. I wish I could tell you which way that is but because there is no picture I had to guess and I can’t remember what my guess was now. 2) the retaining clip in step 26. I was unable to properly seat the logic board back into the machine so that it was flush UNTIL I fooled around with the clip and, I GUESS, put it in properly this time. After I did that I was able to properly push the logic board back into place.
    Christopher Todd - Yanıt
    These comments just reinforce the fact that iFixit should include reassembly instructions! Just saying to reverse the procedure is not adequate. Reassembly often has unique issues that are not encountered during disassembly.
    kevs - Yanıt
    Unless it was seated perfectly when the machine was first put together, the “sock” is likely to come off the logic board assembly when you pop the logic board out. To help reassemble, I have this advice:
    1. The sock has two parts, a stiffer rectangle part and a softer oval part with ridges. The oval part goes towards the outside (back) of the board assembly (where all the receptacles are for the external connections); the rectangle goes towards the inside of the machine.
    2. The rectangle has a stiff, rectangular “magnet-like” piece on one side: that’s the bottom. The top has a slight indentation that fits directly under a “clip” piece on the logic board. That clip is pretty much the only thing holding the sock to the board.
    3. The entire sock does not really seat strongly into the logic board, it’s sort of a gravity fit. So don’t look for places to jam things in: just lay the sock in gently and hook it under the clip and just make sure the oval aligns properly around the socket where the AC cord fits in.
    daniel.brotsky - Yanıt
    This was a huge help!
    Scott Lent -
  26. Mac mini Late 2014 Logic Board Replacement, Heat Sink: adım 26, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement, Heat Sink: adım 26, 2 resimden 2.
    • Remove the following screws securing the heat sink to the logic board:
    • Four 8.6 mm T8 Torx screws
    • One 2.9 mm T6 Torx screw
    • Be careful not to lose the springs held beneath each of the T8 heat sink screws, they may fall off of the screws as you remove them.
    • During reassembly, tighten these screws evenly to ensure the heat sink stays flat against the CPU.
  27. Mac mini Late 2014 Logic Board Replacement: adım 27, 3 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 27, 3 resimden 2. Mac mini Late 2014 Logic Board Replacement: adım 27, 3 resimden 3.
    • Remove the heat sink from the logic board.
    • If the heat sink appears to be stuck to the logic board after removing all screws, it may be helpful to use a spudger to separate the two components.
    • Don't reassemble your Mac mini without applying a new layer of thermal paste.We have a thermal paste guide to show you how.
  28. Mac mini Late 2014 Logic Board Replacement, I/O Bezel: adım 28, 1 resimden 1.
    • Remove the following T6 Torx screws from the I/O port antenna cables:
    • Three 2.8 mm screws with washers
    • One 3.4 mm screw
    • One 2.7 mm screw
  29. Mac mini Late 2014 Logic Board Replacement: adım 29, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 29, 2 resimden 2.
    • Use the point of a spudger to lift the power switch cable connector straight up out of its socket on the logic board.
  30. Mac mini Late 2014 Logic Board Replacement: adım 30, 3 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 30, 3 resimden 2. Mac mini Late 2014 Logic Board Replacement: adım 30, 3 resimden 3.
    • Use the point of a spudger to lift the antenna connectors up off of their sockets on the AirPort card.
  31. Mac mini Late 2014 Logic Board Replacement: adım 31, 1 resimden 1.
    • Remove the four 2.7 mm T6 Torx screws holding the I/O bezel to the logic board.
  32. Mac mini Late 2014 Logic Board Replacement: adım 32, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 32, 2 resimden 2.
    • Remove the foam bumper from between the I/O bezel and USB ports.
  33. Mac mini Late 2014 Logic Board Replacement: adım 33, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 33, 2 resimden 2.
    • Pull the I/O bezel off of the logic board, minding any cables that may get caught.
    • Try not to handle the small steel tabs on the logic board and I/O bezel, as oils from your fingers may cause interference issues. Before installing the logic board assembly, clean the metal tabs to remove any oils transferred during the removal process.
  34. Mac mini Late 2014 Logic Board Replacement, Logic Board: adım 34, 1 resimden 1.
    • Remove the following T6 Torx screws securing the speaker to the logic board:
    • One 3.6 mm screw
    • One 3.6 mm large headed screw
  35. Mac mini Late 2014 Logic Board Replacement: adım 35, 2 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 35, 2 resimden 2.
    • Do not attempt to remove the speaker entirely as it is still attached to the logic board.
    • Nudge the speaker gently out of the way to allow access to the speaker's connector.
  36. Mac mini Late 2014 Logic Board Replacement: adım 36, 3 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 36, 3 resimden 2. Mac mini Late 2014 Logic Board Replacement: adım 36, 3 resimden 3.
    • Use the flat end of a spudger to carefully lift the speaker connector up out of its socket on the logic board.
    • Remove the speaker from the logic board.
  37. Mac mini Late 2014 Logic Board Replacement: adım 37, 1 resimden 1.
    • Remove the 2.7 mm T5 screw securing the AirPort card.
    Where can I get a logic board for the 2014 mac mini?
    Padma Sana - Yanıt
  38. Mac mini Late 2014 Logic Board Replacement: adım 38, 3 resimden 1. Mac mini Late 2014 Logic Board Replacement: adım 38, 3 resimden 2. Mac mini Late 2014 Logic Board Replacement: adım 38, 3 resimden 3.
    • Lift the free end of the AirPort card enough to grasp it by the edges.
    • Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac Mini.
    2014製 Mac mini に接続されたモニターの画面がちらつき始めたので、いろいろと確認しました。
    High Speed 4K HDMI ケーブル が怪しいので確認しました。
    Mac 側のHDMI ケーブルコネクタを動かしたところ、モニターの画面がちらつき始めた
    Apple のサポートに見積もりを取った。5万円の見積もりが来ました。
    axx.hasesan55 - Yanıt
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
465.777 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
4 Yorum
is there any internal battery on the logic board..
sokratis162 - Yanıt
Are all Mac Mini cases the same from 2011 on? Could I take out my 2011 guts and put in one from 2014?
jbasa - Yanıt
hello a question as it is called the piece that contains the hard disk?
Miguel - Yanıt
It is called a hard drive tray or hard drive carrier. You can find the guide to remove it here.
Arthur Shi -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 42
Son 30 gün: 236
Her zaman: 38,883
