Ana içeriğe geç
Mac mini Mid 2011 I/O Bezel Replacement
Walter Galan
Walter Galan ve 3 diğer katkıda bulunanlar
En son June 22, 2019 tarihinde güncellendi
Tahmin yok
Zor
Use this guide to replace the I/O bezel and its integrated antennas. Replacing the I/O bezel will also give you a new power button.
Neye ihtiyacın var
  1. Mac mini Mid 2011 I/O Bezel Replacement, Bottom Cover: adım 1, 2 resimden 1. Mac mini Mid 2011 I/O Bezel Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Mid 2011 I/O Bezel Replacement: adım 2, 1 resimden 1.
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac mini Mid 2011 I/O Bezel Replacement, Fan: adım 3, 1 resimden 1.
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac mini Mid 2011 I/O Bezel Replacement: adım 4, 1 resimden 1.
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
  5. Mac mini Mid 2011 I/O Bezel Replacement: adım 5, 3 resimden 1. Mac mini Mid 2011 I/O Bezel Replacement: adım 5, 3 resimden 2. Mac mini Mid 2011 I/O Bezel Replacement: adım 5, 3 resimden 3.
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
  6. Mac mini Mid 2011 I/O Bezel Replacement, Cowling: adım 6, 1 resimden 1.
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Mac mini Mid 2011 I/O Bezel Replacement: adım 7, 1 resimden 1.
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Mac mini Mid 2011 I/O Bezel Replacement, Antenna Plate: adım 8, 1 resimden 1.
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
    • When putting back together:
    • It can be difficult to get the hard drive seated correctly such that the antenna plate fits in place correctly. If the screw holes don't line up with those on the hard drive, make sure that the two pins that are in the back of the hard drive are properly seated in the holes at the back of the case, above the housing for the second hard drive.
    • The antenna attaches directly to the hard drive (red markers), therefore attaching the antenna can move the hard drive around and loosen the connection of the hard drive cable to the logic board.
  9. Mac mini Mid 2011 I/O Bezel Replacement: adım 9, 2 resimden 1. Mac mini Mid 2011 I/O Bezel Replacement: adım 9, 2 resimden 2.
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Mac mini Mid 2011 I/O Bezel Replacement: adım 10, 1 resimden 1.
    • Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
  11. Mac mini Mid 2011 I/O Bezel Replacement: adım 11, 1 resimden 1.
    • Remove the antenna plate from the mini.
  12. Mac mini Mid 2011 I/O Bezel Replacement, Logic Board: adım 12, 2 resimden 1. Mac mini Mid 2011 I/O Bezel Replacement, Logic Board: adım 12, 2 resimden 2.
    • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
  13. Mac mini Mid 2011 I/O Bezel Replacement: adım 13, 1 resimden 1.
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
    • Make sure to pry up from beneath the wires and not underneath the socket.
  14. Mac mini Mid 2011 I/O Bezel Replacement: adım 14, 1 resimden 1.
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  15. Mac mini Mid 2011 I/O Bezel Replacement: adım 15, 3 resimden 1. Mac mini Mid 2011 I/O Bezel Replacement: adım 15, 3 resimden 2. Mac mini Mid 2011 I/O Bezel Replacement: adım 15, 3 resimden 3.
    Bu adımda kullanılan alet:
    Mac mini Logic Board Removal Tool
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case.
    • Remove the Mac mini Logic Board Removal tool.
  16. Mac mini Mid 2011 I/O Bezel Replacement: adım 16, 1 resimden 1.
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use your fingers to disconnect the DC-In cable from the logic board.
    • Pull the power cable connector toward the front side of the mini.
  17. Mac mini Mid 2011 I/O Bezel Replacement: adım 17, 1 resimden 1.
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
  18. Mac mini Mid 2011 I/O Bezel Replacement, Speaker: adım 18, 1 resimden 1.
    • Remove the following two screws securing the speaker to the logic board assembly:
    • One 3.5 mm T6 Torx screw
    • One 3.7 mm T6 Torx screw
  19. Mac mini Mid 2011 I/O Bezel Replacement: adım 19, 2 resimden 1. Mac mini Mid 2011 I/O Bezel Replacement: adım 19, 2 resimden 2.
    • Lift but do not remove the speaker assembly, as it still remains connected to the logic board via the speaker connector.
    • Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
    • Lift and remove the speaker away from the logic board.
  20. Mac mini Mid 2011 I/O Bezel Replacement, AirPort/Bluetooth Antenna Connectors: adım 20, 2 resimden 1. Mac mini Mid 2011 I/O Bezel Replacement, AirPort/Bluetooth Antenna Connectors: adım 20, 2 resimden 2.
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth board.
  21. Mac mini Mid 2011 I/O Bezel Replacement, I/O Bezel: adım 21, 1 resimden 1.
    • Carefully un-clip the antenna from the logic board near the heat sink.
  22. Mac mini Mid 2011 I/O Bezel Replacement: adım 22, 2 resimden 1. Mac mini Mid 2011 I/O Bezel Replacement: adım 22, 2 resimden 2.
    • Carefully un-clip the antenna from the logic board near the PRAM battery.
    • Gently de-route the antenna cable through the hole in the logic board.
  23. Mac mini Mid 2011 I/O Bezel Replacement: adım 23, 2 resimden 1. Mac mini Mid 2011 I/O Bezel Replacement: adım 23, 2 resimden 2.
    • Carefully un-clip the antenna from the logic board opposite the I/O bezel.
    • De-route the antenna cable from the clips on the logic board near the I/O bezel.
  24. Mac mini Mid 2011 I/O Bezel Replacement: adım 24, 1 resimden 1.
    • Lift the power button cables upward to gently pull the power button cable up and out of its connector on the logic board.
  25. Mac mini Mid 2011 I/O Bezel Replacement: adım 25, 1 resimden 1.
    • Remove the following screws securing the I/O bezel to the front side of the logic board:
    • Three 2.6 mm T6 Torx screws
    • One 2.9 mm T6 Torx screw
  26. Mac mini Mid 2011 I/O Bezel Replacement: adım 26, 1 resimden 1.
    • Remove the single 2.6 mm T6 Torx screw securing the I/O bezel to the logic board near the RAM.
  27. Mac mini Mid 2011 I/O Bezel Replacement: adım 27, 1 resimden 1.
    • Pull the I/O bezel away from the logic board, minding any cables that may get caught.
    • Try not to handle the small steel EMI fingers on the logic board and I/O bezel, as oils from your fingers may cause interference issues. Before installing the logic board assembly, clean the EMI fingers to remove any oils transferred during the removal process.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 5,718
