Ana içeriğe geç
Mac mini Mid 2011 Logic Board Replacement
Neye ihtiyacın var
  1. Mac mini Mid 2011 Logic Board Replacement, Bottom Cover: adım 1, 2 resimden 1. Mac mini Mid 2011 Logic Board Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
    FixBot'a Sor
    Yorum Ekle
  2. Mac mini Mid 2011 Logic Board Replacement: adım 2, 1 resimden 1.
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
    FixBot'a Sor
    Yorum Ekle
  3. Mac mini Mid 2011 Logic Board Replacement, Fan: adım 3, 1 resimden 1.
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
    FixBot'a Sor
    Yorum Ekle
  4. Mac mini Mid 2011 Logic Board Replacement: adım 4, 1 resimden 1.
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
    FixBot'a Sor
    Yorum Ekle
  5. Mac mini Mid 2011 Logic Board Replacement: adım 5, 3 resimden 1. Mac mini Mid 2011 Logic Board Replacement: adım 5, 3 resimden 2. Mac mini Mid 2011 Logic Board Replacement: adım 5, 3 resimden 3.
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
    FixBot'a Sor
    Yorum Ekle
  6. Mac mini Mid 2011 Logic Board Replacement, Cowling: adım 6, 1 resimden 1.
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
    FixBot'a Sor
    Yorum Ekle
  7. Mac mini Mid 2011 Logic Board Replacement: adım 7, 1 resimden 1.
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
    FixBot'a Sor
    Yorum Ekle
  8. Mac mini Mid 2011 Logic Board Replacement, Antenna Plate: adım 8, 1 resimden 1.
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
    • When putting back together:
    • It can be difficult to get the hard drive seated correctly such that the antenna plate fits in place correctly. If the screw holes don't line up with those on the hard drive, make sure that the two pins that are in the back of the hard drive are properly seated in the holes at the back of the case, above the housing for the second hard drive.
    • The antenna attaches directly to the hard drive (red markers), therefore attaching the antenna can move the hard drive around and loosen the connection of the hard drive cable to the logic board.
    FixBot'a Sor
    Yorum Ekle
  9. Mac mini Mid 2011 Logic Board Replacement: adım 9, 2 resimden 1. Mac mini Mid 2011 Logic Board Replacement: adım 9, 2 resimden 2.
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
    FixBot'a Sor
    Yorum Ekle
  10. Mac mini Mid 2011 Logic Board Replacement: adım 10, 1 resimden 1.
    • Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
    FixBot'a Sor
    Yorum Ekle
  11. Mac mini Mid 2011 Logic Board Replacement: adım 11, 1 resimden 1.
    • Remove the antenna plate from the mini.
    FixBot'a Sor
    Yorum Ekle
  12. Mac mini Mid 2011 Logic Board Replacement, Logic Board: adım 12, 2 resimden 1. Mac mini Mid 2011 Logic Board Replacement, Logic Board: adım 12, 2 resimden 2.
    • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  13. Mac mini Mid 2011 Logic Board Replacement: adım 13, 1 resimden 1.
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
    • Make sure to pry up from beneath the wires and not underneath the socket.
    FixBot'a Sor
    Yorum Ekle
  14. Mac mini Mid 2011 Logic Board Replacement: adım 14, 1 resimden 1.
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
    FixBot'a Sor
    Yorum Ekle
  15. Mac mini Mid 2011 Logic Board Replacement: adım 15, 3 resimden 1. Mac mini Mid 2011 Logic Board Replacement: adım 15, 3 resimden 2. Mac mini Mid 2011 Logic Board Replacement: adım 15, 3 resimden 3.
    Bu adımda kullanılan alet:
    Mac mini Logic Board Removal Tool
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case.
    • Remove the Mac mini Logic Board Removal tool.
    FixBot'a Sor
    Yorum Ekle
  16. Mac mini Mid 2011 Logic Board Replacement: adım 16, 1 resimden 1.
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use your fingers to disconnect the DC-In cable from the logic board.
    • Pull the power cable connector toward the front side of the mini.
    FixBot'a Sor
    Yorum Ekle
  17. Mac mini Mid 2011 Logic Board Replacement: adım 17, 1 resimden 1.
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
    FixBot'a Sor
    Yorum Ekle
  18. Mac mini Mid 2011 Logic Board Replacement, PRAM Battery: adım 18, 1 resimden 1.
    • The PRAM battery is located on the top side of the logic board.
    • Use the tip of a spudger to carefully pry the PRAM battery up and out of its holder on the logic board.
    FixBot'a Sor
    Yorum Ekle
  19. Mac mini Mid 2011 Logic Board Replacement: adım 19, 1 resimden 1.
    • Remove the PRAM battery from the logic board.
    • The PRAM battery is a commonly available BR2032 coin-cell.
    FixBot'a Sor
    Yorum Ekle
  20. Mac mini Mid 2011 Logic Board Replacement, Speaker: adım 20, 1 resimden 1.
    • Remove the following two screws securing the speaker to the logic board assembly:
    • One 3.5 mm T6 Torx screw
    • One 3.7 mm T6 Torx screw
    FixBot'a Sor
    Yorum Ekle
  21. Mac mini Mid 2011 Logic Board Replacement: adım 21, 2 resimden 1. Mac mini Mid 2011 Logic Board Replacement: adım 21, 2 resimden 2.
    • Lift but do not remove the speaker assembly, as it still remains connected to the logic board via the speaker connector.
    • Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
    • Lift and remove the speaker away from the logic board.
    FixBot'a Sor
    Yorum Ekle
  22. Mac mini Mid 2011 Logic Board Replacement, AirPort/Bluetooth Board: adım 22, 2 resimden 1. Mac mini Mid 2011 Logic Board Replacement, AirPort/Bluetooth Board: adım 22, 2 resimden 2.
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth board.
    FixBot'a Sor
    Yorum Ekle
  23. Mac mini Mid 2011 Logic Board Replacement: adım 23, 1 resimden 1.
    • Use your spudger to help disconnect the AirPort/Bluetooth ribbon cable from its socket on the AirPort/Bluetooth board.
    FixBot'a Sor
    Yorum Ekle
  24. Mac mini Mid 2011 Logic Board Replacement: adım 24, 1 resimden 1.
    • Remove the two 2.6 mm T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
    FixBot'a Sor
    Yorum Ekle
  25. Mac mini Mid 2011 Logic Board Replacement: adım 25, 1 resimden 1.
    • Remove the AirPort/Bluetooth board from the logic board.
    FixBot'a Sor
    Yorum Ekle
  26. Mac mini Mid 2011 Logic Board Replacement, Logic Board: adım 26, 1 resimden 1.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable up off the logic board.
    • Remove the AirPort/Bluetooth ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  27. Mac mini Mid 2011 Logic Board Replacement: adım 27, 3 resimden 1. Mac mini Mid 2011 Logic Board Replacement: adım 27, 3 resimden 2. Mac mini Mid 2011 Logic Board Replacement: adım 27, 3 resimden 3.
    • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
    FixBot'a Sor
    Yorum Ekle
  28. Mac mini Mid 2011 Logic Board Replacement: adım 28, 1 resimden 1.
    • Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
    FixBot'a Sor
    Yorum Ekle
  29. Mac mini Mid 2011 Logic Board Replacement: adım 29, 1 resimden 1.
    • Remove the following screws securing the heat sink to the logic board:
    • Four 8.6 mm T8 Torx screws
    • One 2.6 mm T6 Torx screw
    • Keep track of the springs held beneath each of the T8 heat sink screws.
    FixBot'a Sor
    Yorum Ekle
  30. Mac mini Mid 2011 Logic Board Replacement: adım 30, 1 resimden 1.
    • Remove the heat sink from the logic board, minding any cables that may get caught.
    • If the heat sink appears to be stuck to the logic board after removing all screws, it may be helpful to use a spudger to separate the two components.
    • If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
    • Logic board remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
25 farklı kişi bu kılavuzu tamamladı.
7Kılavuz Yorumları
Can you replace the logic board in this Mac Mini Server, with one from the newer faster one, such as the 2012 2.6GHZ i7 server?
jim - Yanıt Paylaş
You absolutely can. My mid 2011 Mini logic board died, and I just had a 2012 board put in, which not only upgrades the USB ports to USB3, it also increases bus speed, although the slower RAM 1333 vs 1600 will still work fine.
birdsquared - Yanıt Paylaş
I’m wanting to replace my 2011 Mac mini logic board with a 2012. I have a couple questions.
do you need to upgrade your power supply as well?
would the hard drive get formatted(meaning it’ll wipe the hard drive that has important information)?
thank you.
p.s. Dave posted about changing it with a 2014? Not sure if that’s a thing
Daniel W Olson - Yanıt Paylaş
Is it worth replacing the motherboard and can you get a replacement with an ungraded graphics chip as the 2011 integrated graphics was not designed for 2k or 4k?
It seems to be the only problem with my logic board and it already been burned torched once.
JB Brighton - Yanıt Paylaş
I realize this is an old post. But, I have a Mac Mini 2011 model that works fine, but can no longer update the IOS due to age. I was wondering if I am able to put something like a 2014 logic board in it?
Dave - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 85
Her zaman: 43,147
